RASPDIGI LTE LVDS V2 Streamer I2S LVDS HDMI Allo Kali Reclocker Audio-GD Compatible
We propose you a model updated of our RaspDIGI LTE with this version V2. This takes advantage of the solid base of the first version, namely the management of the I2S signal and the reclocking of the signal;The MCLK can be used by the Allo Kali to ensure a high quality sound reproduction, while expanding the list of compatible DAC thanks to a new I2S / HDMI interface.
4.5 / 5
By buying this product you get 26 loyalty points
Reference : 13064
269,00 €tax incl.
224,17 € tax excl.
This product is delivered without a pre-installed software solution. Computer skills are therefore necessary. In case of doubt, do not hesitate to contact us.
It is necessary to install a generic driver to use this device. The most common are RPI_DAC, Hifiberry DAC and ES9023.
RaspDIGI LTE I2S LVDS V2
Streamer Raspberry Pi 3 B+ I2S HDMI LVDS Reclocker Allo Kali Audio-GD  compatible
RaspDIGI LTE I2S LVDS V2 Lecteur réseau Raspberry Pi 3 B I2S HDMI LVDS Reclocker Allo Kali Compatible Audio-GD / Gustard
Play your music in high definition
This RaspDIGI LTE V2 opens the doors to high definition materialized music. You can thus have the practical aspect of the network player, by going directly to get your music on your local network, all at a distance. This way, you can enjoy your high definition files and the quality that comes with them.
But this listening quality is also enabled by an efficient design thanks to I2S signal management with HDMI LVDS output but also thanks to the Allo Kali, providing a previous clock for a drastically harsh jitter.
With regard to the software solution, you are free to choose the one that best suits your desires and needs, RaspDIGI being compatible with most OS for Raspberry Pi. However, we recommend Volumio, piCorePlayer and DietPi distributions, which are particularly suitable for audio use.
Volumio
piCorePlayer
DietPi
Allo Kali
An audiophile mix with I2S LVDS and Allo Reclocker 44 / 48MHz
To provide high quality playback, this RaspDIGI LTE V2 uses and transcribes the I2S signal provided by the Raspberry Pi 3 B+. This one has the advantage of requiring as little conversion as possible.
To obtain the highest possible I2S signal quality, the RaspDIGI LTE V2 incorporates an I2S FIFO Allo Kali reclocker. This one provides an ultra low jitter 44 / 48MHz clock powered by LDO and an ultra quiet power supply.
Thus, Kali will be able to process the I2S signal from the Raspberry Pi 3 B+ to get the most accurate synchronization. The processed signal is then redirected to an I2S to LVDS interface on HDMI connector and balanced.
This combination delivers incredible audio performance that won’t be long in coming: your music opens, the sound stage extends, and the hitherto inaudible details are now perceptible.
A wider compatibility
If the previous version of the RaspDIGI LTE was already compatible with many DACs and especially the excellent converters from Audio-GD, this version goes even further by expanding the list of compatible devices. Thus, a jumper on the I2S / HDMI interface module allows you to choose between two positions, to adapt the device to the pinout of your DAC.
You will find below a non exhaustive list of brands proposing compatible DAC.
The pin "DSD on" is not managed, the DSD reading is possible only with DAC with processor of signal able to detect this format, as for example the Armature Asterion.
To ensure the compatibility of your DAC, we strongly recommend that you check its pinout and clock frequency in th table, HDMI tab I2S Format.
  • Audio-GD
  • Sonore
  • PS Audio
  • Wyred4Sound
  • Musica Pristina
  • DiDiT High-End
  • Holo Audio
  • Audiobyte
  • K&K Audio
  • Gustard
  • Armature
RaspDIGI LTE V2
Pinout Audio-GD standard
RaspDIGI LTE LVDS V2
A sober and elegant design
The RaspDIGI LTE V2 always benefits from its compact format, allowing it to be easily integrated into an audio system. In addition, it has a 100% brushed aluminium case that is both robust and sober and elegant. The back of the case is now also silkscreened, indicating each port.
ModulesRaspberry PI 3 B+
Reclocker Allo Kali 44/48MHz
Interface I2S vers HDMI
Inputs4x USB-A
1x Ethernet RJ45
Micro SD
Output1x HDMI (Raspberry PI)
1x I2S HDMI LVDS
Power Supply5V 3A (included)
Supported sample rates32bit 384kHz
Dimensions102 x 167 x 55mm
Weight620g
ColorBlack / Black front
InputRJ45
InputMicro SD
OutputHDMI
OutputI2S LVDS via HDMI
Max sampling rate384kHz
ColorSilver
2 reviews
Good device
Reasonably priced. Easy to configure. Sounds great over I2S
This review has been posted for RASPDIGI LTE LVDS V2 Streamer I2S LVDS HDMI Allo Kali Reclocker Audio-GD Compatible
A great piece of kit
I brought this for my Audio-GD R8 dac and it's been great, its a step up from the USB out of my silent PC into the Audio-GD, I can follow instruments better now, before they would get slightly lost in the mix, there is better separation between instruments and the music sounds ever so slightly more organic.
It benefits slightly from a good linear power supply, I'm using the Allo Shanti to not only power the Raspdigi but also my external 2TB SSD, and the highs are slightly cleaner now with more extension and air around them, on first listen the bass seemed a bit weaker, but it turned out the bass had tightened up a bit and was less bloated giving the impression there was less bass.
I'm running picoreplayer because I think it sounds slightly better than Volumio, Dietpi and Moode, plus because it runs in ram I can just power off the unit without risk of corrupting the SDCard.
I highly recommend this product, its fantastic value, its slightly cheaper than a Gustard U16 USB to i2s converter, and on top of that its also a streamer and player, so you have access to hundreds of internet radio stations, streaming services, youtube and so on.
 (3)
We propose you a model updated of our RaspDIGI LTE with this version V2. This takes advantage of the solid base of the first version, namely the...
