RASPTOUCH I-SABRE ES9038Q2M Streamer with Touchscreen 32bit 384kHz DSD128
With the RaspTouch, Audiophonics offers a simple and efficient hardware solution combining both network player and DAC. The device offers outstanding audio quality thanks to a high level digital to analog conversion based on a ES9038Q2M DAC.
4.8 / 5
Reference : 12181
499,00 €tax incl.
415,83 € tax excl.
RaspTouch I-Sabre ES9038Q2M
RaspTouch I-Sabre ES9038Q2M Lecteur réseau tactile 32bit 384kHz DSD128
The Concept
The RaspTouch allows you to enjoy your favorite music while controlling playback from its 7" touch screen, your smartphone or even your computer. The dedicated audio playback circuit works with a Raspberry Pi 4 SBC (Single Board Computer). This circuit is the reference in the field making the RaspTouch a completely Open Source solution.
With its large screen and wide audio connectivity, the RaspTouch combines ergonomics and fine sound reproduction for enhanced musical enjoyment.
The DAC
For this version of the RaspTouch, Audiophonics integrates the excellent ES9038Q2M converter supporting sample rates up to 32bit 384kHz. This integrates a 100MHz precision clock, low noise LDO regulation, an ultra-low noise (9µV) regulator for the ESS chip reference voltage and an Altera processor.
This DAC uses 32bit HyperStream technology offering a wide dynamic range while drastically reducing jitter. Thanks to this design, the ES9038Q2M has a dynamic range of 129dB and a THD+N of -120dB to offer you new musical horizons.
The 32bit Attenuation technology allows a volume adjustment without loss of quality, making it possible to do without a preamplifier. This hardware volume control can be controlled from the Raspberry Pi thanks to the dedicated driver available in our Volumio image or under DietPi.
Thanks to the built-in microprocessor, the DAC is able to automatically detect the source's sample rate format and adapt to it automatically. It thus detects whether the source is 16, 24 or 32bit while remaining bit perfect. This PLCD chip control maintains high stability while preventing decoding problems and the appearance of listening artifacts.
Combined with the Raspberry Pi it is compatible with formats up to 32bit 384jHz in PCM and up to DSD128 in DoP. It includes two NJM 2114 bipolar operational amplifiers powered in 9V for the current/voltage conversion section, which allows a high quality analog output. A last NJM 2214 AOP used in buffer finalizes the analog output stage and ensures an optimal restitution.
Connectivity
The RaspTouch offers a complete set of connectors that will allow you to enjoy your audio system with ease. The Raspberry Pi 4 has 2 USB-A 2.0 ports, 2 USB-A 3.0 ports, a Micro SD slot, an Ethernet RJ45 port and a remote HDMI output. It is possible to connect all kinds of compatible peripherals to the USB ports:
  • Hard disk or USB flash drive
  • WiFi USB dongle
  • External USB DAC
  • Keyboard / Mouse
The DAC offers an analog output on stereo RCA. Power is supplied by a 5.5/2.1mm DC jack plug connected to an integrated linear power supply for good stability. The optimal input voltage is 7 to 9VDC.
The ignition button not only turns off the power, but also starts the system to shut down beforehand. It can also be switched off via the Volumio interface.
Despite the Raspberry Pi 4 's native WiFi connectivity, the latter was sacrificed to install the reader in a disturbance-isolated aluminum enclosure. The WiFi connection therefore requires an external software adapter to USB (WiFi Dongle).
The Software
Advertising itself as a free system, the RaspTouch comes without an operating system. This choice depends on your hardware, the ambition of your project, and the expected functionalities.
The unit is ready for use electronically, so all that remains to be done is to choose an operating system and mount it on the supplied Micro SD card. Many software solutions exist, in order to meet all your expectations: piCorePlayer, Volumio, Max2Play, OpenElec...
Depending on the solution you choose, you will be able to access the following features:
  • Unlimited Full Multiroom Support
  • Remote playback of audio files stored on a Network Attached Media Server (NAS)
  • Remote playback from an UpNP source
  • Playback from USB source (hard disk, USB flash drive)
  • DLNA protocol
  • Support for Qobuz, Spotify...
  • AirPlay Support
The unit is delivered with a Micro SD card suitable for the installation of the operating system.
Product typeStreamer
Inputs4x USB-A 2.0
1x Ethernet RJ45
1x Micro SD slot
Outputs1x Stereo RCA
1x HDMI
DACI-Sabre ES9038Q2M
DSD DoP up to DSD128
Dynamic range129dB
THD+N-120dB
Screen7" capacitive touchscreen, 800 x 400px
Raspberry Pi 4
ChipsetBroadcom BCM2711
CPUQuad Core Cortex-A72 (ARM v8) 64bit SoC @ 1.5GHz
LANOnly with USB dongle
Bluetooth version5.0
Dual-core Videocore IV Multimedia Coprocessor-
Memory2Gb LPDDR4
Housing materialAluminium
Dimensions200 x 95 x 230mm
Weight1490g
power supplyJack DC 5.5/2.1mm 7.5V 2.9A (included)
Package1x RaspTouch I-Sabre ES9038Q2M
1x Micro SD card 8GB
1x Alimentation
InputRJ45
InputMicro SD
OutputHDMI
OutputCoaxial SPDIF
DAC / ADC ChipES9038Q2M
Max sampling rate768kHz
Streaming services & Network protocolsSpotify
Streaming services & Network protocolsTidal
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsTidal Connect
4 reviews
Rasptouch.
La configuration demande de suivre scrupuleusement le tuto fait par audiophonics.
Heureusement celui-ci est bien fait.
Le son est excellent !
L'utilisation de l'écran tactile est sympa et l'appli sur smartphone pratique.
Attention le Rasptouch demande à être connecté en filaire. Le wifi même avec un dongle spécifique raspberry ne fonctionne pas.
Fonctionne avec tidal ou qobuz, même band camp avec un plug-in.
Je ne regrette pas d'avoir pris le temps d'apprivoiser l'appareil. J'ai configuré un ssd avec toute ma discothèques en flac (ne fonctionne pas sans connexion internet), l'accès à certaines radios est possible. Toutes les radios France par exemple.
Je suis très satisfait du produit mais il n'est pas simple au début. Mais en plug en play dans d'autres marques c'est minimum le double du prix. Sans l'écran de 7 pouces...
This review has been posted for RASPTOUCH I-SABRE ES9038Q2M Streamer with Touchscreen 32bit 384kHz DSD128
Super produit !
Dès que j'ai appris l'existence du Rasptouch, je savais que c'était la solution pratique, élégante et qualitative pour me créer un serveur et lecteur de musique. Le problème avec la musique dématérialisée c'est que je devais toujours avoir un ordinateur allumé ou un téléphone à côté de moi pour en profiter. J'ai longuement hésité à créer une solution DIY à base de RaspberryPi plus simple, sans écran, mais je me suis payé le luxe du "tout intégré" pour mon salon. Je n'ai plus vu les pièces séparées sur le site d'audiophonics... J'ai donc commandé la version pré-assemblée. Avec l'interface Jivelite de Logitech Media Server (via piCorePlayer) je peux facilement laisser mes jeunes enfants (4 ans et 6 ans) choisir leur musique ou lire leurs livres d'histoire audio à l'aide d'une playlist dans les favoris. Ils peuvent facilement naviguer dans la musique car le player offre une image pour les artistes et pour les jaquettes (de CD) virtuelles.
J'avoue que j'ai du bien me renseigner avant l'achat afin de bien comprendre l'écosystème des lecteurs Raspberry pi. Mon choix s'est assez vite posé sur la distribution piCorePlayer qu'Audiophonics à l'air de recommander, qui est très légère et tourne dans la RAM (ce qui complique parfois un peu les choses car pour gérer certaines choses par rapport à Volumio ou MoodeAudio car il faut charger des modules qui ne sont pas chargés par défaut). Je trouve que les fonctionnalités libres, OpenSource et gratuites de piCorePlayer sont vraiment géniales et exceptionnelles. Au passage, Merci à la communauté pour le logiciel et la qualité des informations sur les forums. De plus, comme l'OS est chargé en RAM il y a moins de risques de corrompre le système de fichiers en cas de panne de courant ou d'arrêt "intempestif" du Raspberry Pi.
Je vous conseille vivement d'installer le "material theme" lorsque vous contrôlez le lecteur via téléphone ou ordinateur. Il est simplement magnifique, intuitif et pratique.
J'ai mis quelques jours à configurer le Wifi et j'ai vraiment du jouer de la déduction pour trouver comment compiler le driver de mon adaptateur Wifi USB mais je viens de réussir à compiler, créer un module à charger par défaut au démarrage et à tout connecter (j'ai eu un cable USB qui traverse mon salon pendant une petite semaine, le temps de trouver)
Donc, petit conseil si vous n'êtes pas un as du ssh et des commandes linux... essayez de trouver un adaptateur Wifi USB compatible directement, peut-être qu'Audiophonics pourra vous aider dans votre quête. Ou, si votre configuration intérieure vous le permet, passez par un cable Ethernet.
Je compte de tout de façon faire une vidéo explicative pour guider l'utilisateur 'novice' à compiler le driver de son adaptateur USB car j'en ai un peu bavé... Il y a quelques vidéos qui expliquent comment installer la distribution piCorePlayer, configurer l'émulateur de lecteur audio Squeezelite et le serveur LMS avec l'interface Jivelite mais j'ai vraiment du chercher toutes les pièces du puzzle pour compiler et charger un driver wifi... donc, je trouve que c'est important que si quelqu'un se trouve face au même problème que moi... il n'ait pas à chercher pendant des heures pour faire quelque chose qui, quand on connaît et comprend la procédure, est totalement réalisable sans perdre trop de temps. J'inclurai aussi l'installation de base ainsi que la manière de configurer le (script) pour le bouton pour allumer et éteindre le Rasptouch car certaines informations que j'ai pu trouver sur les forums ne sont parfois plus totalement à jour. ;-)
Conclusion : J'ai un lecteur/serveur musical pour mes fichiers numériques que je peux lire dans mon salon directement via le piCorePlayer, dans ma cuisine via mon ancien lecteur Marantz CR510 qui n'a jamais vraiment fonctionné optimalement mais qui fonctionne à merveille aujourd'hui grâce au pont Upnp, j'ai aussi installé un émulateur squeezelite player sur mon mac dans mon bureau pour avoir accès à ma bibliothèque musicale via le Rasptouch. Le pied ! Je vais sans doute encore créer un projet Rpi pour que ma compagne puisse profiter de la musique dans son bureau. Je vais pouvoir libérer l'espace sur mon mac et ne plus utiliser iTunes. Je peux aussi lire des Webradios, des podcasts et me connecter à Spotify, Deezer, Tidal, Qobuz, si j'en ai envie, même si je n'ai pas encore d'abonnement streaming. (En particulier car je trouve qu'ils ne rétribuent pas assez les artistes et que le modèle économique de Spotify n'est pas valide car ils ne sont pas rentables, contrairement à Bandcamp qui est rentable en ne prenant que 15%, le reste va aux artistes) J'ai par contre installé et configuré les plugin Bandamp, Youtube et Soundcloud qui fonctionnent parfaitement.
Si j'ai un problème, si je veux upgrader le Rasptouch ou si j'ai un problème technique, j'ai un système où je peux remplacer les pièces sans problème : Changer un RasperryPi n'est pas compliqué. J'ai un contrôle sur les updates logiciels et j'ai confiance en la communauté. Une bien meilleure expérience qu'avec mon player Marantz qui dont le côté fermé le rendait peu attractif et peu intuitif aujourd'hui pour l'usage que j'en avais. Ma plus grande surprise est que je peux le réutiliser aujourd'hui sans trop d'inconvénients en "multiroom" en combinaison avec le Rasptouch !
Je ne suis pas assez audiophile pour vous parler des qualités du DAC tout ce que je peux dire c'est que c'est transparent, dynamique et les aigus sont bien représentés (les graves et les médiums aussi d'ailleurs). Le Rasptouch est branché à des KEF Reference 105.1 dans mon salon et je trouve le son exceptionnel. En streaming, via le Marantz et des vieilles B&W DM2 mk2 qui ne servaient plus et que j'ai récupérées dans la cave de ma mère, il donne aussi très bien mais là ce n'est plus le DAC du Rasptouch qui est en jeu. ;-)
Désolé pour cet avis long comme une "tartine" mais je pense que vous comprenez mon enthousiasme pour le Rasptouch. Je n'avais sans doute pas "besoin" d'un DAC aussi performant mais comme qui dirait, qui peut le plus, peut le moins. ;-) Comparé à des lecteurs commerciaux de type audiophile c'est vraiment moins cher et plus upgradable/réparable... même la version KALI qui est encore un peu plus chère que celle-ci me semble intéressante pour les inconditionnels des fréquences d'échantillonnage les plus hautes possibles. Bon au final, il faut être un peu geek pour tout installer soi-même mais, j'aime ça, donc... pas de problème. ;-)
 (3)
Totalement satisfait de ce lecteur réseau, exactement ce que je recherchais (merci à David pour ces conseils) Très simple d'utilisation et d'une efficacité redoutable. Le son est vraiment très bon, j'ai comparé en aveugle le son d'un CD lu par ma platine et la version rippée (lossless) lue par ce rasptouch et c'est difficile d'entendre une différence, un son légèrement plus "sec" avec le rasp mais une meilleure "spatialisation".
Très bonne alternative aux produits nettement plus chers pour une qualité très proche.
Tout dépendra évidemment des exigences de chacun, du matériel existant mais surtout (et on ne le dit pas assez souvent) du style de musique écouté.
Simply wonderful!!!
Purchased one couple of months ago.
As was originally suggested, loaded Rune Audio onto micro SD card, booted the unit, and it came up - with the screen upside down. At first I thought some one messed up and mounted the screen upside down. Turns out it was a software issue, common to many players.
I contacted Audiophonics, and after few email discussions, loaded the latest Volumio player. Everything was great - except I had no sound. After numerous email exchanges, I had Audiophonics email me assembly instructions.
I took the player completely apart, and reassembled it again. In the process I discovered that one of the GPIO pins was bent and had no contact with DAC connector - most probably the reason for sound issues.
Once again I started the unit, this time using PiCore Player and Logitech Music Server. I connected the streamer to the Emotiva USP-1 preamp, mated to Emotiva UPA-200 stereo amp and Magnepan MG 3.7 speakers and HSU Research ULS-15 Subwoofer.
Few hi-res recordings from Primophonics instantly convinced me that this player was well worth all the aggravation:
the sound was simply wonderful.
I can't wait to convert some of my organ music LPs to HiRes WAV or FLAC or maybe DSD files and play them on my RaspTouch!!! It will be glorious!
 (4)
With the RaspTouch, Audiophonics offers a simple and efficient hardware solution combining both network player and DAC. The device offers...
