Just arrived It don't work. The PSU is damaged. I'm still waiting for replacement
The Audiophonics team is proud to present its new version of RaspTouch, the RaspTouch LTE. Based on a Raspberry Pi 3 and one DAC I-Sabre ES9023, it offers an out-of-pair compatibility with many platforms, allowing you to enjoy your entire library. In addition, its design has been revised to offer you a space-saving and flexible solution.
Comes with piCorePlayer pre-installed, this operating system allows you to enjoy just the whole of your audio library. So, whether your music is stored physically on a hard drive connected to your Raspberry Pi or on a server, you can access it without any limitation while enjoying your I-Sabre ES9023 DAC.
More than that, it works with Squeezelite and Logitech Media Server to turn your RaspTouch LTE into a true network player ,allowing you to remotely control your system. Even better, you can download and use applications like iPeng or Squeezer in order to control your player with your smartphone, directly from your sofa.
Finally, to ensure more compatibility, your device is compatible UPnP, DLNA and Airplay, allowing you to simply stream your content to your turntable.
Want to enjoy your music throughout your home? The RaspTouch LTE takes care of it by offering an efficient multiroom system, allowing you to stream your files on any deck connected to your network and control them.
Because for us you must be able to adapt your system to your needs, we made the choice of the " Open Source. Thus, if piCorePlayer does not suit you, you are free to choose the solution that will be most effective for your uses. Raspbian, Max2Play or Kodi work perfectly with the RaspTouch LTE for example.
Based on a DAC I-Sabre ES9023capable of converting sampling rates up to 24bit / 192kHz and equipped with Ultra-low noise regulators and Low ESR filter capacitors, the RaspTouch LTE is definitely a high-end audio / video deck.
Raspberry Pi 3, DAC I-Sabre ESS 9023 and 7 "Raspberry official touch screen allows you to tilt or fix your deck as you wish, in order to adapt to your use and your environment without any restriction.
Inputs | |
x4 | USB-A |
x1 | Ethernet RJ45 |
x1 | Micro USB-B (Power Supply) |
x1 | Slot Micro-SD |
Outputs | |
1x | RCA Stéréo |
I-SABRE ES9023 | |
Sample rate | 24bit 192kHz |
Régultateurs Ultra Low Noise | Oui |
Low ESR Filter Capacitors | Oui |
RASPBERRY PI 3 | |
Chipset | Broadcom BCM2837 1.2Ghz |
Core | ARM Cortex A53 64bit 4 coeurs |
LAN | Wireless |
Bluetooth | 4.1 |
GPU | DualCore |
Memory | LPDDR2 1Go |
Screen & Stand | |
Screen | 7" Capacitive touch 10 fingers |
Resolution | 800 x 400 px |
Support | SmartiPi Tiltable |
Dimensions & Weight | |
Weight | 548g |
Dimensions | 22L x 9.7 x 13.8H |
Contenu du colis | ||
![]() | - Streamer Touch control Rasptouch LTE I-Sabre | x1 |
![]() | - Wall adapter 100-240V ro Micro-USB 5V 3A. | x1 |
Average votes 2.3 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Joe M.
Julien T.
David c.
