The Rasptouch ES9018K2M is a network drive with DAC ES9028K2M equipped with a 7 "touch screen and based on a Raspberry Pi.
KEY POINTS:
By buying this product you get 42 loyalty points
Max2play touchscreen network player with Raspberry Pi and DAC I-Sabre ES9018K2M
The 7 "touchscreen of this audio player is easy to use and gives you complete control over your music library. The pre-installed and operational Max2Play software solution offers a wide range of features and uses.
Its CNC chassis is 100% aluminum and machined via a numerical control machine, allowing it to have a modern and contemporary design.
The RaspTouch was developed in order to offer all HiFi enthusiasts a simple, elegant, affordable, and especially High Resolution compatible solution to play your favorite music.
Usereading the Raspberry Pi and Max2Play, we offer you the possibility to get a ready-to-use high-definition network player: developed by Audiophiles for audiophiles. This community is constantly evolving and continues to bring improvements and new features, allowing it to be one of the best "OpenSource" solutions.
We allons bring to your music library a higher level of requirement with the RaspTouch.
This RaspTouch project was first launched on KickStarter, and we can proudly tell you that the campaign was a great success, thanks to everyone! That's why we now offer all the models on our site, so that the bigger world can enjoy it.
Based on a latest generation DAC (ES9018K2M), capable of converting sampling rates up to 32bit / 384kHz, we can say that we are in the company of a high-end audio / video player that will perfectly match your inside.
Raspberry Pi 3 | Model B |
DAC | Audiophonics I-Sabre ES9018K2M 32bit / 384kHz / 127dB |
screen | official touch Raspberry 7 " |
<inputs/ Td> | 1x RJ45 / 4x USB-A / 1x Micro SD Port |
Exits | 1x RCA Stereo / 1x HDMI |
Operating system | Max2Play pre-installed |
Food | Jack DC 5.5 / 2.1mm / Supplied with power supply 7V / 3A |
Housing material | 100% Aluminum |
Color | Black |
Dimensions | 200 x 95x 230mm |
Rear dimensions | 175 x 55mm |
Weight | 0.9kg |
