RaspTouch I-Sabre V3 - Streamer touch Raspberry Pi & DAC ES9023 Silver
The Rasptouch Audiophonics is a network player based on Raspberry Pi with a touch screen for easy use. It is declined here in its version with DAC I-Sabre V3 ES9023, TCXO and silver color frame.
4.0 / 5
By buying this product you get 34 loyalty points
Reference : 11255
349,00 €tax incl.
290,83 € tax excl.
AUDIOPHONICS RaspTouch ES9023 Silver
Max2play touch screen network player with Raspberry Pi and DAC I-Sabre V3 ES9023 TCXO
RaspTouch
The 7 "touchscreen of this audio player is easy to use and gives you complete control over your music library. Open Source software such as Max2Play, Kodi, PiCorePlayer ... offers a wide range of features and uses.
Its CNC chassis is 100% aluminum and machined via a numerical control machine, allowing it to have a modern and contemporary design.
Miniature-Rasptouch-es9023-face-2.jpgMiniature-Rasptouch-es9023-arri% C3% A8re -Miniature-Rasptouch-es9023-composants-biMiniature-Rasptouch-es9023-convertisseur
RaspTouch - The best player "Open Source"
The RaspTouch was developed in order to offer all HiFi enthusiasts a simple, elegant, affordable, and especially High Resolution compatible solution to play your favorite music.
Usereading the Raspberry Pi, we offer our customers the opportunity to choose the software solution they want and that is best suited to their needs. Solutions such as Picore Player, Kodi, Raspbian and RuneAudio have been tested and are working with our RaspTouch. However, if you are looking for a 100% ready-to-use product, you can opt for editing with Max2Play preinstalled , then you just have to plug it in and play your music.
We will bring to your music library a levelwith the RaspTouch.
Rasptouch
This RaspTouch project was first launched on KickStarter, and we can proudly tell you that the campaign was a great success, thanks to everyone! That's why we now offer all the models on our site, so that the greatest world can benefit.
A high fidelity and design audio player
Based on a latest generation DAC (ES9023), capable of converting sampling rates up to 24bit / 192kHz, we can say that we are in the company of a high-end audio / video player that will perfectly match your inside.
Specifications DAC I-Sabre ES9023
  • Patented Jitter® Disposal Technology
  • Dynamic range 112dB
  • Power Management Prevents SD Card Errors
  • Clock TCXO high precision 0.5ppm (ultra low jitter)
  • Hyper-Stream® technology
  • Output Level 2Vrms
Rasptouch
Rasptouch
Chassis Aluminum or chassis Aluminum + official touch screen 7 "
There are also these 2 DIY Kit versions, in order to leave the field open to all creators and imaginatives. The world of Do It Yourself is available to you!
Châssis rasptouch
Rasptouch
Raspberry Pi 3Model B
DACAudiophonics I-Sabre V3 ES9023 TCXO
Screenofficial touch Raspberry 7 "
inputs1x RJ45 / 4x USB-A / 1x Micro SD Port
Exits1x RCA Stereo / 1x HDMI
FoodJack DC 5.5 / 2.1mm / Supplied with 6V / 3A power supply
Housing material100% Aluminum
ColorBlack & Silver
Dimensions200 x 95x 230mm
Rear Dimensions175 x 55mm
Weight0.9kg
Quality built unit
Once I saw this unit, I knew I wanted to get it for the bedroom. Tried looking for local North American sellers, but could not find one. Shipping was quite fast and arrived well packed. If you don't have an adapter to go from European to North American socket then order one with your unit. Very sleek design. A design change that I would like to see is, have the ability to adjust the angle of the display. Having all the I/O cable come out the back is also great idea to have a clean setup. I have my original setup using the SmartiPi Touch case which is nice, network cable comes out the side and a few other.
This review has been posted for RaspTouch I-Sabre V3 - Streamer touch Raspberry Pi & DAC ES9023 Silver
The Rasptouch Audiophonics is a network player based on Raspberry Pi with a touch screen for easy use. It is declined here in its version with DAC...
