SparkDIGI LTE I2S - I2S LVDS Network Player Audio-GD Compatible
Reference : 12131
149,00 €tax incl.
124,17 € tax excl.
If you have any doubts about the compatibility and/or functioning of this product, please do not hesitate to contact us.
Audiphonics SparkDIGI
Streamer I2S LVDS HDMI
Audiophonics SparkDIGI
Audiophonics expands its line-up with a brand new network drive, based on a Kali controlled SBC and an I2S LVDS digital interface via HDMI port. A solution that is therefore Audio-GD compatible and certainly audiophile.
The dematerialized has never been so close
With SparkDIGI, you can simply enjoy your entire dematerialized high definition audio library, without limits! Remotely controllable from your Volumio interface, you can access files on your server intuitively and efficiently. So you can enjoy your music from the couch.
Volumio: A more than complete DAP
volumio
Audiophile quality
This high fidelity DAP is a true audiophile solution tailored to deliver bit-perfect playback and uncompromising audio quality.
Limitless
Volumio lets you play all your music: MP3, FLAC, WAV, AAC, ALAC, DSD and more. You can also enjoy the UPNP/DLNA, Airplay, Spotify and web radio stations at the same location.
Open source
This player also proves to be open source, developed by a talented team and an active community.
volumio interface
I2S LVDS: Exceptional sound quality
Instead of using the usual signals, this SparkDIGI offers you to enjoy an extremely clean I2S LVDS signal via a dedicated Audio-GD digital interface. The latter is responsible for symmetrizing the signal. All you have to do is plug the SparkDIGI into your DAC with an HDMI I2S LVDS port to enjoy your music and exceptional sound reproduction.
Attention: the HDMI output is only I2S balanced and is therefore not usable for video. It will soon be available from this page.
SparkDigi I2S LVDS
Many compatible DACs
To enjoy your SparkDIGI turntable, simply choose your HDMI I2S LVDS DAC, such as the Audio-GD DAC-19 or NOS-19 Audio-GD. Of course many other models exist. Here is the list of brands by proposing (not exhaustive)
  • Matrix X-Sabre Pro
  • Astin Trew
  • Audio Byte
  • Rockna
  • Javs
  • K&K Audio
  • Love Harmony
  • PS Audio
  • Sonore
  • Stahl Tec Optus DAC
  • Wired 4 Sound
SparkDIGI compatible DAC Audio-GDSparkDIGI Compatible dac matrix
Sober and elegant design
The SparkDIGI, assembled in a 100% aluminium housing, has a sober yet elegant design that will fit seamlessly into your Hifi system. Designed in our workshops in France, this case will protect the system components from shock and dust.
SparkDigi
Connectors : Inputs
USB-A2x
Ethernet RJ451x
Micro SD Slot1x
Connectors : Outputs
HDMI (I2S LVDS)1x
Sparky
CPUARM Cortex A9 Quad Core 1.1GHz
Memory1Go RAM DDR3L
GPUPowerVR SGX544 / 500MHz
Dimensions102 x 169 x 58mm
Weight580g
Power SupplyJack DC
Accessories5V 3A Power Supply
Mapping I2S / LVDS
A synthesis of main IIS on LVDS pinouts mapping is available here.
OutputI2S LVDS via HDMI
