Active SPDIF Optical Toslink Switch 3 to 1
This SPDIF switch has three inputs and one output in Toslink optical format. It allows you to multiply the number of sources for the same output, and to easily select the active source, either with the button on the front of the device, or via the remote control provided.
Reference : 15639
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 07-05-2025.
Optical Toslink
Switch SPDIF Actif Optique Toslink 3 vers 1
This SPDIF switch has three inputs and one output in Toslink optical format. It allows you to multiply the number of sources for the same output, and to easily select the active source, either with the button on the front of the device, or via the remote control provided. The switch supports PCM streams up to 24bit 192kHz and is compatible with PCM 2.0, DTS and Dolby AC3 formats.
Product typeOptical Toslink switch
Inputs3x Optical Toslink
Output1x Optical Toslink
Supported sampling ratesPCM up to 24bit 192kHz
Supported audio formatsPCM 2.0
DTS
Dolby AC3
Supply voltage5VDC
Dimensions95.5 x 53 x 20mm
ColorNoir
Package1x Optical switch
1x Remote control
1x Optical cable
1x Power cable USB-A to Jack DC 5.5/2.1mm
Connectic
  • Female
Switch qualitatif
Bon matériel, conforme à la description, fonctionne bien, aspect qualitatif, tout métal. Bon rapport qualité/prix
This review has been posted for Active SPDIF Optical Toslink Switch 3 to 1
This SPDIF switch has three inputs and one output in Toslink optical format. It allows you to multiply the number of sources for the same output,...
