Converter 192kHz Coaxial to Optical / Optical to Coaxial
With this compact and easy to use converter, you can convert Coaxial to Toslink and vice versa.
It is compatible with digital audio streams up to 192kHz.
It is also equipped with a signal amplifying circuit, which allows it to serve as a repeater to increase the effective length of wirings without suffering signal loss.
A selector located on the side of the device allows to specify which between Toslink and Coaxial inputs is active. The opposite output (coaxial output if input Toslink active and vice versa) is activated automatically.
The unit requires a 5VDC power supply. It can be powered either by a DC input jack 5.5 / 2.1mm or via a mini-USB port.
Type | Digital converter |
Inputs | S / PDIF Coaxial S / PDIF Toslink Optical |
Outputs | S / PDIF Coaxial S / PDIF Toslink Optical |
Power Supply included | DC5V |
Dimensions | 54.45 x 61.20 x 20.5mm |
