Male HDMI to Female HDMI Panel Mount 1.4 Ethernet CEC 50cm
This 50cm HDMI 1.4 partition passe will allow you to extend an HDMI connection as part of a DIY project in a box, a piece of furniture or any other partition. Its conductors are made of copper and its contacts are gold-plated to ensure very good conductivity. In addition, its triple layer shielding greatly reduces EMI/RFI interference that could impact the signal and produce noise. The cable is compatible with video definitions up to 1080p (Full HD) and offers bandwidth up to 5Gbps. It also supports Ethernet and CEC.
Specifications | ||
Product type | HDMI Panel Mount | |
Length | 50cm | |
Cable diameter | 7.8mm | |
Conductors material | Copper | |
Contacts plating | Gold | |
Video definition compatibilité | 1080p, 1080i, 720p, 480p | |
Number of supported audio channels | 8 | |
Cable shielding | Yes - Triple shielding | |
Bandwidth | Up to 5Gbps | |
CEC Compatibility | Yes | |
Ethernet Support | Yes | |
Fixation holes spacing | 30mm | |
Screw thread | M3 | |
Cable color | Black |
