Panel Mount USB-A 3.0 Male to USB-A 3.0 Female Blue 0.5m
This pass-through port incorporates a male-to-male 3.0-angled connector on one side and a female-to-female port on the other.
Reference : 12553
5,90 €tax incl.
4,92 € tax excl.
Shipping date: 25-04-2025.
Pass-through Micro-B 3.0 Wall Male To Elbow to USB-A Female 0.5m
This pass-through port incorporates a male-to-male 3.0-angled connector on one side and a female-to-female port on the other. The cable, 50cm long, will allow you to easily integrate into your DIY installations and creations, in order to take advantage of an offset of your connectors.
The cable benefits from a quality construction, with a copper conductor and shielding to limit magnetic interference. In addition, its USB 3.0 connectors ensure optimal data transmission speed.
TECHNICAL CHARACTERISTICS
  • Cable Length: 50cm
  • Connectors: Micro-B Male / USB-A Female
  • USB Standard: 3.0
  • Blue color
  • Lead cable: Copper
  • Shielding: Double Aluminum Sheet
  • Sheath: PVC
  • Max. Wall thickness: 4.5mm
  • Mounting distance: 30mm
ColorBlue
MaterialN/A
Length (m)0.5
ShieldingYes
ConnecticMale & Female
ConnectorUSB-A
Internal widthN/A
Internal depthN/A
Internal heightN/A
