DAYTON AUDIO DMA58-PR Passive Radiator Aluminum 39.8Hz Ø50.8mm
The Dayton Audio DMA58-PR 2" passive radiator is a perfect option for providing a bass boost to small speakers. Although small in size, the DMA58-PR has all the features you'd expect from larger models, including adjustable mass, aluminum diaphragm and rubber suspension.
Reference : 17207
8,90 €tax incl.
7,42 € tax excl.
This product is temporarily unavailable.
Dayton Audio DMA58-PR Radiateur Passif Aluminium 39.8Hz Ø50.8mm
Product typePassive radiator
Nominal diameterØ50.8mm (2")
Mounting circle diameterØ65mm (2.56")
Resonant frequency (Fs)39.8Hz
Mechanical quality factor (Qms)3.93
Compliance equivalent volume (Vas)7.08L (0.025ft³)
Mechanical compliance of suspension (Cms)2.4mm/N
Diaphragm mass inc. airload (Mms)6.7g
Maximum linear excursion (Xmax)7mm
Surface area of cone (Sd)14.5cm²
Materials
Cone materialAluminum
FramePolymer
Mounting informations
Overall outside dimensions55.9*55.9mm
Cutout diameter50.04mm
depth38.1mm
Mounting holes number4
Speaker Power (W RMS)NC
Speaker TypePassive Radiator
Impedance (Ω)NC
Loudspeaker diameter (mm)51.0
Diaphragm typeAluminium
Max Linear Excursion (Xmax) (mm)7.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
The Dayton Audio DMA58-PR 2" passive radiator is a perfect option for providing a bass boost to small speakers. Although small in size, the...
