DAYTON AUDIO DMA80-PR Aluminium Passive Radiator 34.6Hz Ø7.6cm
The Dayton Audio DMA80-PR is a 7.6cm diameter passive radiator. This is an excellent solution for a boost in bass in smaller speakers. This small passive radiator has everything you would expect from larger models, including an adjustable mass, an Aluminium diaphragm and a rubber suspension.
Reference : 13904
10,90 €tax incl.
9,08 € tax excl.
Shipping date: 29-09-2026.
Grantie 5 ans
Dayton Audio DMA80-PR Radiateur Passif Aluminium 34.6Hz Ø7.6cm
The Dayton Audio DMA80-PR is a 7.6cm diameter passive radiator. This is an excellent solution for a boost in bass in smaller speakers. This small passive radiator has everything you would expect from larger models, including an adjustable mass, an Aluminium diaphragm and a rubber suspension. Visually identical to the Dayton Audio DMA Series wideband speakers, this DMA80-PR can also be used with any other small speaker requiring reinforcement in the low frequencies. The threaded rod and wing nut included at the back of the diaphragm allow easy adjustment of the mass to adjust the passive radiator to your project.
In general, a passive radiator must have at least twice the air displacement (Vd) of the system's active loudspeaker/subwoofer. To calculate the air displacement: Vd = Sd x Xmax.
Operation of a passive radiator
The passive radiator (or passive loudspeaker) fits into a box with an active loudspeaker. This passive radiator, while at first glance it may look like a "classic" loudspeaker, does not actually have any engine parts. Thus, there will be no coil, magnet or power supply in its design. Similarly, it will not be electrically connected to a power amplifier.
To diffuse sound, the passive radiator will use the air pressures and depressions induced by the active loudspeaker in the body to vibrate its membrane and produce a sound, thus providing deep bass. Its resonance frequency is determined by its mass and the air contained in the enclosure. It will therefore be possible to vary its resonance frequency on many models and tune it to the speaker by adding or removing mass.
Fonctionnement d'un radiateur passif
Technical charcateristics
Product typePassive radiator
Speaker driver rangeDMA
Nominal diameterØ7.6cm (3")
Resonant frequency (Fs)34.6Hz
Mechanil quality coefficient (Qms)8.91
Compliance equivalent volume (Vas)0.071 ft.³
Mechanical compliance of suspension (Cms)1.41 mm/N
Diaphragm mass inc. airload (Mms)13.7g
Max linear excursion (Xmax)7mm
Surface area of cone (Sd)31.2cm²
Cone materialAluminium
Basket materialPolymer
Mounting informations
Total external dimensions80.5 x 80.5mm
Cutout diameter74.4mm
Depth44.7mm
Bolt circle diameter95.2mm
Mounting holes number4
Speaker Power (W RMS)NC
Speaker TypePassive Radiator
Impedance (Ω)NC
Loudspeaker diameter (mm)76.0
Diaphragm typeAluminium
Max Linear Excursion (Xmax) (mm)7.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
The Dayton Audio DMA80-PR is a 7.6cm diameter passive radiator. This is an excellent solution for a boost in bass in smaller speakers. This small...
