DAYTON AUDIO DS135-PR Passive Radiator
The Dayton Audio DS135-PR passive radiator is ideal for replacement or speaker design. An integrated ground disk offers a good starting point for most designs, and a convenient M5 threaded hole (screw included) allows different types of weight to be added if required.
Reference : 19975
23,90 €tax incl.
19,92 € tax excl.
This product is temporarily unavailable.
Dayton Audio DS135-PR Radiateur Passif Papier 27.7Hz Ø12.7cm
Dayton Audio DS135-PR : Side view
The Dayton Audio DS135-PR passive radiator is ideal for replacement or speaker design. An integrated ground disk offers a good starting point for most designs, and a convenient M5 threaded hole (screw included) allows different types of weight to be added if required. This passive radiator features a polyethylene-coated paper diaphragm and rubber suspension for clean excursion and durability. As a result, this model offers a wide range of integration possibilities.
Dayton Audio DS135-PR : Dimensions
Product typePassive radiator
Nominal diameterØ12.7cm (5")
Weight227g
Total outer dimensionsØ135 x 38.1mm
Thiele-Small parameters
Resonant frequency (fS)27.2Hz
Mechanical quality factor (QMS)3.93
Compliance equivalent volume (VAS)12.18L (0.43ft³)
Mechanical compliance of suspension (CMS)1.52mm/N
Moving mass + airload (MMS)21.8g
Max linear excursion (XMAX)8mm
Surface area of cone (SD)75.4cm²
Materials
ConePaper
SurroundRubber
FrameSteel
Mounting informations
Outer dimensionsØ135 x 38.1mm
Cutout diameterØ111.5mm (4.39")
Depth38.1mm (1.5")
Bolt circle diameterØ126mm
Number of mounting holes4
Speaker Power (W RMS)
  • NC
Speaker Type
  • Passive Radiator
Impedance (Ω)
  • NC
Loudspeaker diameter (mm)
  • 127.0
Diaphragm type
  • Paper
Efficiency / Sensitivity (dB)
  • N/A
Max Linear Excursion (Xmax) (mm)
  • 8.0
Lowest frequency (Hz)
  • N/A
Highest frequency (Hz)
  • N/A
DAYTON AUDIO DS135-PR Passive Radiator Paper 27.7Hz Ø12.7cm
The Dayton Audio DS135-PR passive radiator is ideal for replacement or speaker design. An integrated ground disk offers a good starting point for...
