DAYTON AUDIO DSA175-PR Passive Radiator 26.8 Hz Ø 16.5cm
A well-made passive radiator with aluminum diaphragm, designed to fit most 16cm format loudspeaker modernization/repair projects. It boasts a high excursion of 8mm, enabling it to emphasize the lower end of the spectrum s while maintaining the dynamic range of the sound. It can therefore be easily integrated into precision loudspeaker projects, capable of developing large volumes without taking up too much space.
Reference : 13294
27,90 €tax incl.
23,25 € tax excl.
Shipping date: 24-04-2025.
DSA175-PR 6-1 / 2 "
Passive Radiator Aluminum ⌀16.5cm
DSA175-PR 6-1 / 2
Radiator speaker passive
A passive radiator aluminum membrane of good quality, designed to fit most of the modernization projects / repair speaker 16cm format.
It has a high excursion of 8 mm, which serves to emphasize the low end s while maintaining the dynamics of sound. It can thus be easily integrated into the precision speaker projects capable of developing large volumes without much clutter.
Its design as much as its specifications make it a very suitable radiator with the DESIGNER series in Dayton Audio. This did however not stop to offer excellent performance with other models.
To facilitate integration of the radiator and quickly achieve the best sound, the DSA175-PR comes with M5 screws, which will add weight to the radiator. This configuration lowers the resonant frequency in order to promote the natural balance of bass.
Adjusting mass resonance frequency passive radiator
Typepassive radiator
Nominal diameter16.5cm
Resonant Frequency26.8 HzFs
Mechanical Q4.3Qms
total moving mass air + Load30.7gMms
Compliance of the suspension1.15 mm / NCms
emitting surface of the membrane128.7 cm²sd
Volume displaced air388.3 cm³MD
compliance equivalent volume of air26.9you
maximum excursion8 mmXmax
mechanical loss2.3 kg / sRms
Membrane / diaphragmaluminum Cone
borderRubber
bowl materialSteel
overall external diameter17.5cm
overall depth4.7cm
drilling diameter14.4cm
Number of mounting holesx5
belt diameter16.6cm
Diameter (mm)16.0
Max Linear Excursion (Xmax) (mm)8.0
A well-made passive radiator with aluminum diaphragm, designed to fit most 16cm format loudspeaker modernization/repair projects. It boasts a high...
