DAYTON AUDIO DSA215-PR Passive Radiator 25.6Hz Ø20cm
A well-made passive radiator with aluminum diaphragm, designed to fit most 20cm speaker modernization/repair projects. It has an 11mm excursion, enabling it to emphasize the lower end of the spectrum without distorting the dynamic range of the sound. It can therefore be easily integrated into large, ambitious loudspeaker projects.
Reference : 13319
36,90 €tax incl.
30,75 € tax excl.
This product is temporarily unavailable.
DSA215-PR 8 "
Passive Radiator Aluminum ⌀20cm
A passive radiator aluminum membrane of good quality, designed to fit most of the modernization projects / repair speaker 20cm format.
It has a 11mm tour, allowing to emphasize the low end without distorting the dynamics of sound. It may therefore be integrated easily into evocative and ambitious projects pregnant.
Its design as much as its specifications make it a very suitable radiator with the DESIGNER series in Dayton Audio. This did however not stop to offer excellent performance with other models.
To facilitate integration of the radiator and quickly achieve the best sound, the DSA207-PR comes with M5 screws, which will add weight to the radiator. This configuration lowers the resonant frequency in order to promote the natural balance of bass.
Typepassive radiator
Nominal diameter20cm
Resonant Frequency (Fs)25.6 Hzfs
Mechanical Q (Qms)7.66qms
total moving mass air + Load67gmms
Compliance of the suspension0.58 mm / Ncms
emitting surface of the membrane211.2 cm²sd
Volume displaced air232.4 cm³Vd
compliance equivalent volume of air36.7 litersVas
maximum excursion11 mmXmax
mechanical loss1.4 kg / srms
Membrane / diaphragmaluminum Cone
borderRubber
bowl materialSteel
overall external diameter215.9 mm
overall depth58.42 mm
drilling diameter178.05 mm
Number of mounting holes5
belt diameter205.99 mm
Speaker Power (W RMS)NC
Speaker TypePassive Radiator
Impedance (Ω)NC
Loudspeaker diameter (mm)200.0
Diaphragm typeAluminium
Max Linear Excursion (Xmax) (mm)11.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
A well-made passive radiator with aluminum diaphragm, designed to fit most 20cm speaker modernization/repair projects. It has an 11mm excursion,...
