DAYTON AUDIO DSA315-PR Passive Radiator 17.5Hz Ø30.5cm
A passive radiator aluminum membrane of good quality, designed to fit most of the modernization projects / repair speaker 30.5cm format.
Reference : 15173
75,00 €tax incl.
62,50 € tax excl.
Last items in stock !
Shipping date: 24-04-2025.
DSA315-PR 12"
Passive Radiator Aluminum ⌀30.5cm
Dayton Audio DSA315-PR
It has a high excursion of 13 mm, which serves to emphasize the low end s while maintaining the dynamics of sound. It can thus be easily integrated into the precision speaker projects capable of developing large volumes without much clutter.
Its design as much as its specifications make it a very suitable radiator with the DESIGNER series in Dayton Audio. This did however not stop to offer excellent performance with other models.
To facilitate integration of the radiator and quickly achieve the best sound, the DSA315-PR comes with M5 screws, which will add weight to the radiator. This configuration lowers the resonant frequency in order to promote the natural balance of bass.
TypePassive radiator
Nominal diameter30.5cm
Resonant Frequency17.5HzFs
Mechanical Q6.23Qms
Compliance equivalent volume6.74ft³Vas
Mechanical compliance of suspension0.58mm/NCms
Max linear excursion13mmXmax
Surface area of cone480cm²Sd
Moving mass of diaphragm142.6cm²Mmd
MembraneAluminum
SurroundRubber
Basket / FrameSteel
External diameter313.9mm
Depth88.9mm
Cutout diameter272mm
Number of mounting holes5
Bolt circle diameter304mm
Speaker Power (W RMS)NC
Speaker TypePassive Radiator
Impedance (Ω)NC
Loudspeaker diameter (mm)305.0
Diaphragm typeAluminium
Max Linear Excursion (Xmax) (mm)13.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
