DAYTON AUDIO EPIQUE E150HE-PR Passive Radiator
Combining excellent performance with a reasonable price, the Dayton Audio Epique E150HE-PR passive radiator with carbon fiber diaphragm is the perfect companion for the MMAG subwoofers in the Epique range. Its carbon fiber diaphragm, custom-machined supension and cast aluminum bowl give this passive radiator a low resonant frequency (Fs), making it possible to use more compact speaker boxes.
Reference : 18497
42,90 €tax incl.
35,75 € tax excl.
Last items in stock !
Shipping date: 24-04-2025.
Dayton Audio EPIQUE E150HE-PR
Passive Radiator Carbon Fiber Ø139.7mm
DAYTON AUDIO E150HE-PR Radiateur Passif Fibre de Carbone Ø139.7mm
When designing the E150HE-PR, Dayton Audio paid particular attention to optimizing the rubber suspension to ensure high linear excursion without limiting performance. Similarly, special care was taken with the spider.
The optimized profiles of the diaphragm and dome prevent distortion when the passive radiator is subjected to high stress, while considerably reducing distortion. Likewise, the sturdy cast-aluminum bowl is highly resistant to mechanical stress. Three discs allow perfect tuning of the passive radiator.
Product typePassive radiator
Nominal diameterØ139.7mm (5.5")
Mounting bolt diameterØ140mm
Parameters
0 disk1 disk2 disks3 disks
Mmpr (g)76.5109138167
Fpr (Hz)3024.922.120.1
Qmpr3.333.984.484.93
Vapr (L)4.814.814.814.81
Cmpr (mm/N)0.380.380.380.38
Rmpr (kg/s)4.294.294.294.29
Xmech (mm)19191919
Sd (cm²)95959595
Vd (cm3)180.5180.5188.5180.5
Materials
DiaphragmCarbon fiber
FrameCast aluminum
Mounting informations
Total outer diameterØ152 x 48.5mm
Cutout diameter126.5mm
Depth48.5mm
Number of mounting holes4
Speaker Power (W RMS)NC
Speaker TypePassive Radiator
Impedance (Ω)NC
Loudspeaker diameter (mm)140.0
Diaphragm typeCarbon fiber
Max Linear Excursion (Xmax) (mm)19.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
DAYTON AUDIO EPIQUE E150HE-PR Passive Radiator Carbon Fiber Ø139.7mm
Combining excellent performance with a reasonable price, the Dayton Audio Epique E150HE-PR passive radiator with carbon fiber diaphragm is the...
