DAYTON AUDIO EPIQUE E180HE-PR Passive Radiator Carbone Fiber 16.3-22Hz Ø17.8cm
Combining excellent performance with a reasonable price, the Dayton Audio Epique E180HE-PR passive radiator is the perfect companion to the Epique series of MMAG subwoofers. Featuring a carbon fiber diaphragm, custom machined surround, and a cast aluminum frame, the E180HE-PR has a low resonant frequency that allows for more compact speaker cabinets without the need for long ports.
Reference : 17721
47,90 €tax incl.
39,92 € tax excl.
Last items in stock !
Shipping date: 29-04-2025.
Passive Radiator Carbon Fiber 16.3-22Hz Ø17.8cm
Dayton Audio Epique E180HE-PR Radiateur Passif Fibre de Carbone Ø17.8cm
When designing the E180HE-PR, Dayton Audio paid particular attention to optimizing the surround to ensure unrestricted excursion without limiting performance. The large rubber surround was custom made to allow for high linear excursion and a custom spider was designed to lower the resonant frequency for maximum performance and easy tuning.
The rigid carbon fiber diaphragm gives the E180HE-PR many performance advantages. It offers excellent damping properties for optimal control. Its optimized shape ensures that the diaphragm will not deform, even when exposed to high mechanical stress. The result is a smooth response and low distortion, even when the diaphragm is subjected to high excursion.
In order to withstand such linear excursions, the Dayton Audio Epique E180HE-PR uses a robust cast aluminum frame. Its minimalist design eliminates unwanted distortion and provides ample room for the back of the diaphragm.
Product typePassive radiator
Nominal diameterØ17.8cm
Diaphragm materialCarbon fiber
SurroundRubber
FrameCast aluminum
External diameter181mm
Depth54mm
Cutout diameter151.5mm
Number of mounting holes6
Bolt circle diameter140mm
Parameters
0 disk1 disk2 disks3 disks
Mmpr110g143.5g172g200.7g
Fpr22Hz19.3Hz17.6Hz16.3Hz
Qmpr3.544.384.73
Vapr12.52L12.52L12.52L12.52L
Cmpr0.48mm/N0.48mm/N0.48mm/N0.48mm/N
Rmpr4.34kg/s4.34kg/s4.34kg/s4.34kg/s
Xmech19mm19mm19mm19mm
Sd136.1mm²136.1mm²136.1mm²136.1mm²
Vd258.59³258.59³258.59³258.59³
Speaker Power (W RMS)NC
Speaker TypePassive Radiator
Impedance (Ω)NC
Loudspeaker diameter (mm)178.0
Diaphragm typeAluminium
Max Linear Excursion (Xmax) (mm)19.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
avis du produit
les articles bien reçu, bien emballés et la qualité est exceptionnelle. cependant je n'ai pas encore installé pour essayer. j'ajouterai un commentaire une fois testé.
This review has been posted for DAYTON AUDIO EPIQUE E180HE-PR Passive Radiator Carbone Fiber 16.3-22Hz Ø17.8cm
Combining excellent performance with a reasonable price, the Dayton Audio Epique E180HE-PR passive radiator is the perfect companion to the Epique...
