Radiateur Passif 24Hz Ø10.2cm
The Purifi PTT4.0PR is a high performance passive radiator of 10.2cm (4") diameter. It integrates a Natural Surround suspension developed by the brand and a Bimax spider. It is capable of a large linear excursion and has an adjustable mass.
To develop this model, Purifi used mathematical models to optimize as much as possible and independently each element that can generate distortion.
The passive radiator (or passive loudspeaker) is integrated in a box with an active loudspeaker. This passive radiator, if at first sight it can look like a "classic" loudspeaker, does not in fact have any motor part. Thus, we will not find in its design a coil, a magnet and a power supply. In the same way, it will not be electrically connected to a power amplifier.
To diffuse sound, the passive radiator will use the air pressures and depressions induced by the active loudspeaker in the cabinet to vibrate its membrane and restore sound, thus providing deep bass. Its resonance frequency is determined by its mass and the air contained in the cabinet. We can therefore vary its resonance frequency on many models and tune it to the speaker by adding mass.
Product type | Passive radiator |
Nominal diameter | Ø10.2cm (4") |
Resonant frequency (FS) | 24Hz |
Mechanical quality factor (QMS) | 7 |
Diaphragm mass inc. airload (MMS) | 30g |
Mechanical compliance of suspension (CMS) | 1.41mm/N |
Surface area of cone (SD) | 57cm² |
Maximum linear excursion (VD) | 79.8cm³ |
Compliance equivalent volume (VAS) | 6.4L |
Maximum linear excursion (Xmax) | 14mm |
MAterial | |
Cone material | Proprietary fibre mix |
Surround material | Nitrile rubbe |
Frame material | Aluminum alloy diecast |
Mounting informations | |
Overall outside diameter | Ø125mm |
Cutout diameter | Ø100mm |
Depth | 39.5mm |
Bolt circle diameter | Ø115mm |
Number of mounting holes | 6 |
Speaker Power (W RMS) | NC |
Speaker Type | Passive Radiator |
Impedance (Ω) | NC |
Loudspeaker diameter (mm) | 102.0 |
Diaphragm type | N/A |
Efficiency / Sensitivity (dB) | N/A |
Max Linear Excursion (Xmax) (mm) | 14.0 |
Lowest frequency (Hz) | N/A |
Highest frequency (Hz) | N/A |
