PURIFI PTT6.5PR-NF1-01 Passive Radiator 17Hz Ø16.5cm
The Purifi PTT6.5PR is a high performance passive radiator of 16.5cm (6.5") diameter. It integrates a Natural Surround suspension developed by the brand and a Bimax spider. It is capable of a large linear excursion and has an adjustable mass.
Reference : 16015
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 24-04-2025.
Purifi PTT6.5PR-NF1-01
Radiateur Passif 17Hz Ø16.5cm
Purifi PTT6.5PR-NF1-01 Radiateur Passif 17Hz Ø16.5cm
To develop this model, Purifi used mathematical models to optimize as much as possible and independently each element that can generate distortion.
The passive radiator (or passive loudspeaker) is integrated in a box with an active loudspeaker. This passive radiator, if at first sight it can look like a "classic" loudspeaker, does not in fact have any motor part. Thus, we will not find in its design a coil, a magnet and a power supply. In the same way, it will not be electrically connected to a power amplifier.
To diffuse sound, the passive radiator will use the air pressures and depressions induced by the active loudspeaker in the cabinet to vibrate its membrane and restore sound, thus providing deep bass. Its resonance frequency is determined by its mass and the air contained in the cabinet. We can therefore vary its resonance frequency on many models and tune it to the speaker by adding mass.
Purifi PTT4.0PR-NF2-01 Radiateur Passif 24Hz Ø10.2cm
Product typePassive radiator
Nominal diameterØ16.5cm (6.5")
Resonant frequency (FS)17Hz
Mechanical quality factor (QMS)10.9
Diaphragm mass inc. airload (MMS)80g
Mechanical compliance of suspension (CMS)1.05mm/N
Surface area of cone (SD)133cm²
Maximum linear excursion (VD)199.5cm³
Compliance equivalent volume (VAS)26.2L
Maximum linear excursion (Xmax)15mm
MAterial
Cone materialProprietary fibre mix
Surround materialNitrile rubbe
Frame materialAluminum alloy diecast
Mounting informations
Overall outside diameterØ176mm
Cutout diameterØ144mm
Depth48.7mm
Bolt circle diameterØ166mm
Number of mounting holes6
Speaker Power (W RMS)NC
Speaker TypePassive Radiator
Impedance (Ω)NC
Loudspeaker diameter (mm)165.0
Diaphragm typeN/A
Max Linear Excursion (Xmax) (mm)15.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
The Purifi PTT6.5PR is a high performance passive radiator of 16.5cm (6.5") diameter. It integrates a Natural Surround suspension developed by...
