ATOHM FURTIVE SUB Active Subwoofer White
By buying this product you get 98 loyalty points
Reference : 11247
989,00 €tax incl.
824,17 € tax excl.
The FURTIVE SUB is a unique and coordinated aesthetic to our FURTIVE satellite, with a minimal thickness (16.5cm!), A discreet and elegant alternative to the everlasting cubes. FURTIVE SUB provides a very precise, fast and deep bass sound. Thanks to its performance and its plethora of configurations, it combines perfectly with the wall speakers of the Furtive range as well as with all conventional small and medium size speakers.
You will findyear documents attached 2 PDF files on ATOHM's FURTIVE range.
Features:/ Strong>
  • Subwoofer active: Wall / Load close
  • Frequency response: 30 - 150Hz
  • Amplifier module: ATOHM S250
  • Effective Power: 220Weff
  • Peak Power: 320W
  • Low level input: 2x RCA
  • High level input: 2x 4mm banana / Direct clamping
  • Cut-off frequency: Adjustable from 38 to 150Hz
  • Phase control: 0-180 °
  • Filter slope: Adjustable 12dB - 24dB - LFE
  • Boomer low medium: LD230CR04
  • Power consumption: 320W max
  • Case: MDF 22mm
Packaging:
  • Finish: Satin White
  • Dimensions: 560x500x165mm
  • Weight: 25kg
  • Wall stand and bracketprovided
  • Sold individually
ColorWhite
