Bookshelf Speakers 2-Way 80W 88dB 55Hz-20kHz Walnut (Pair)
The Ariane 1 is the smallest bookshelf speaker model from Davis Acoustics, yet it benefits from the most advanced technological solutions. With two ways, they are equipped with a woofer/midrange with glass fiber diaphragm of 13cm in diameter and a 25mm soft dome tweeter, associated with a good quality filter. They ensure a linear sound reproduction of a beautiful musicality, allowing long hours of listening without auditory fatigue. The Bass Reflex system placed at the front allows to provide deep bass. The Ariane 1s are perfectly suited for an audio installation in a small room.
Product type | Bookshelf speakers |
Number of ways | 2 |
Number of speakers | 2 |
Bass Reflex | |
Nominal power | 80W |
Max power | 110W |
Sensitivity | 88dB |
Frequency response | 55Hz - 20kHz |
Impedance | 5 min. |
Tweeter | Soft dome Ø25mm |
Medium / Woofer | Fiberglass diaphragm Ø13cm |
Cutoff frequency | 4000Hz |
Dimensions (L*P*H) | 160*200*280mm |
Weight | 6.2kg |
Finish / Color | Walnut and white front |
Quantity | Pair (2 speakers) |
Color | Wood |
Color | Walnut |
Impedance (Ω) | 5 |
Impedance (Ω) | 8 |
Efficiency / Sensitivity (dB) | 88.0 |
Lowest frequency (Hz) | 55 |
Highest frequency (Hz) | 20000 |
Power (W) | 80.0 |
Number of loudspeakers | 2 |
Speaker type | Passive |
Speaker form factor | Bookshelf speaker |
