DAVIS ACOUSTICS MIA 20 Bookshelf Speakers 2 Way 80W 88dB 55Hz-20kHz Noir (Pair)
The smaller Davis Acoustics model, the MIA 20s benefit from advanced technological solutions that can be found in higher range models. These small 2-way bookshelf speakers are equipped with a 13cm fiberglass boomer/midrange offering a good transient regime while ensuring low mechanical deformation.
Reference : 13995
175,00 €tax incl.
145,83 € tax excl.
Davis Acoustics MIA 20
Enceintes Bibliothèques 2 Voies 80W 88dB 55Hz-20kHz (La paire)
Davis Acoustics MIA 20 Enceintes Bibliothèques 2 Voies 80W 88dB 55Hz-20kHz (La paire)
The smaller Davis Acoustics model, the MIA 20s benefit from advanced technological solutions that can be found in higher range models. These small 2-way bookshelf speakers are equipped with a 13cm fiberglass boomer/midrange offering a good transient regime while ensuring low mechanical deformation, as well as a soft dome tweeter made of 25mm coated fabric. In addition, the speaker body contains a high quality crossover filter, providing linear listening for long hours of listening without listening fatigue while providing accurate playback. A Bass Reflex system with a large front vent allows you to deliver deep bass. The frontal positioning of these vents allows the MIA 20 to be placed directly against a wall. The 88dB efficiency of these speakers allows them to be associated with all amplifiers on the market.
At the rear, the speaker offers screw terminals that accept banana plugs, but also a system that allows the speakers to be simply positioned against a wall.
Test des Davis Acoustics MIA 20 par On-Mag
" Listening, the Davis Mia 20 are real HiFi speakers that have a lot of charm. For the price at which they are offered, there is not much to complain about. We know of many more expensive ones that sound much worse. "
Product typeSpeakers
Speaker typeBookshelf speaker
PowerNominal : 80W RMS
Max : 110W
Number of way2
Number of speakers2
Sensitivity88dB
Bandwidth55Hz - 20kHz
Tweeter25mm, soft dome
Medium / Woofer13cm, fiberglass
ImpedanceMin. 5Ω
Cutoff frequency3000Hz
Bass ReflexFront laminar vent
Binding post typeScrew bind post. Banana plugs compatible.
Dimensions (LxHxP)16.5 x 27 x 20cm
Weight / speaker3.1kg
Finition and colorDark Ash
QuantitySold per pair (2 speaker)
Impedance (Ω)5
Efficiency / Sensitivity (dB)88.0
Lowest frequency (Hz)55
Highest frequency (Hz)20000
Power (W)80.0
Number of ways2
Number of loudspeakers2
The smaller Davis Acoustics model, the MIA 20s benefit from advanced technological solutions that can be found in higher range models. These small...
