DAYTON AUDIO B452 Bookshelf Speakers 2-Way 30W 6 Ohm 84dB 85Hz - 20kHz (Pair)
The Dayton Audio B452 are small, low-cost bookshelf speakers. They are equipped with a 11.4cm woofer with polypropylene membrane and 4 layers moving coil, as well as a 15.8mm ferrofluid cooled polycarbonate tweeter. This design allows to reach a beautiful sound balance and a surprising richness for such affordable speakers.
Reference : 16420
62,90 €tax incl.
52,42 € tax excl.
Dayton Audio B452
Dayton Audio B452 Enceintes Bibliothèque 2 Voies 30W 6 Ohm 84dB 85Hz - 20kHz (La paire)
The Dayton Audio B452 are small, low-cost bookshelf speakers. They are equipped with a 11.4cm woofer with polypropylene membrane and 4 layers voice coil, as well as a 15.8mm ferrofluid cooled polycarbonate tweeter. This design allows to reach a beautiful sound balance and a surprising richness for such affordable speakers.
The B452s also use a wood composite cabinet that minimizes resonance and enhances warmth without sacrificing clarity. These speakers also occupy a small space of only 14cm wide and 15.2cm deep, making them an ideal choice for desktop listening or a compact surround system. A built-in wall-mounting bracket makes it easy to attach the B452 to the wall wherever you want.
Product typeBookshelf speaker
Power handlingRMS : 30W
Max : 60W
Impedance6Ω
Frequency response85Hz - 20kHz
Sensitivity84dB 1W/1m
Woofer diameterØ114.3mm
Woofer diaphragmPolypropylene
Woofer voice coilBobine 4 couches
Tweeter diameterØ15.8mm
Tweeter diaphragmPolycarbonate
Dimensions139.7 x 144.8 x 241.3mm
Impedance (Ω)6
Efficiency / Sensitivity (dB)84.0
Lowest frequency (Hz)85
Highest frequency (Hz)20000
Power (W)30.0
Number of ways2
Number of loudspeakers2
Speaker typePassive
Speaker form factorBookshelf speaker
The Dayton Audio B452 are small, low-cost bookshelf speakers. They are equipped with a 11.4cm woofer with polypropylene membrane and 4 layers...
