Dayton Audio's Classic B65 bookshelf speakers are passive speakers featuring a 16.51cm woofer and a 2.54cm silk tweeter capable of handling up to 40W RMS of power under a 6 Ohms load (75W max.). They are equally suited to hi-fi and home-cinema applications, and can be used to sound a room of up to 20m². The Classic B65 features a sealed cabinet to reduce low-frequency distortion. Their sensitivity of 85dB and frequency response of 55Hz to 22kHz make them good speakers at a more than reasonable price. The rear panel features a high-quality terminal block and a practical wall-mounting bracket for easy integration in any space.
Dayton audio Classic B65 speakers highlights:
The durable 16.51cm woofer delivers deep bass.
The tweeter delivers detailed highs for smooth, clear vocals.
The suspension structure with sealed cabinet greatly reduces low-frequency distortion.
The Classics B65 benefit from a pleasing vintage look, allowing them to be harmoniously integrated into a complete sound system.
Dayton Audio B65s feature gold-plated terminal blocks for enhanced conductivity and resistance to corrosion and oxidation. In addition, a wall-mounting bracket facilitates their integration in a home-cinema configuration, allowing them to be installed on either side of a screen quickly and easily. Finally, two speaker cables are supplied for immediate use.
Product type | Bookshelf speakers |
Speaker type | Passives |
Number of ways | 2 ways |
Woofer | Polypropylene 16.51cm |
Tweeter | Silk dome 2.54cm |
Frequency response | 55Hz-20kHz |
Sensitivity | 85dB (2.83V/1M) |
Potential output | 98dB |
Power handling | 40W RMS 75W max. |
Recommanded power amplification | 15W-60W |
Nominal impedance | 6 Ohms |
Structure | Sealed (acoustic suspension) |
Crossover frequency | 4kHz |
Dimensions | 198 x 330 x 170mm |
Weight | 2.7kg/speaker |
Color | Wood |
Package | 1x Pair of Dayton Audio Classic B65 bookshelf speakers 2x Front grilles 8x Foam adhesive feets 2x Speaker cables |
Color | Wood |
Impedance (Ω) | 6 |
Efficiency / Sensitivity (dB) | 85.0 |
Lowest frequency (Hz) | 55 |
Highest frequency (Hz) | 20000 |
Power (W) | 40.0 |
Number of ways | 2 |
Number of loudspeakers | 2 |
Speaker type | Passive |
Speaker form factor | Bookshelf speaker |
