DAYTON AUDIO IO65XTW Speakers Indoor / Outdoor 2 Ways with Passive Radiator IP66 50W (Pair) White
Using a passive radiator, Dayton Audio's IO65XT speakers are equally well suited for indoor and outdoor use. They can be powered by a 70/100V amplifier for commercial installations or by an 8Ω amplifier for consumer use. A selector switch allows you to choose an option quickly and easily depending on your use.
By buying this product you get 32 loyalty points
Reference : 17855
329,00 €tax incl.
274,17 € tax excl.
This product is temporarily unavailable.
    Dayton Audio IO65XTW
    Dayton Audio IO65XTW Blanc
    This model is capable of producing extended bass using a passive radiator for deep and punchy bass reproduction. The top of the audio spectrum is reproduced with a 1" silk dome tweeter, offering a nice precision in the midrange and treble.
    In addition, the IP66 protection rating and the ABS chassis of these speakers allow for outdoor use, as they are not affected by bad weather conditions.
    The IO65XT comes with brackets that allow for vertical or horizontal mounting and can be rotated for quick, easy and convenient installation.
    Dayton Audio IO65XTB Enceintes Intérieur / Extérieur 2 Voies avec Radiateur Passif IP66 50W
    Product typeSpeakers
    Power handlingRMS : 50W @ 8Ω
    Max : 100W @ 8Ω
    Frequency response45Hz - 20kHz
    Impedance8Ω / 70V
    SPL86dB 1W/1m
    LoudspeakersPassive radiator 6.5"
    Silk dome tweeter 1"
    Protection classIP66
    Dimensions285.7 x 200.7 x 195.6mm
    Weight3.45kg
    ColorWhite
    ColorWhite
    Impedance (Ω)8
    Efficiency / Sensitivity (dB)86.0
    Lowest frequency (Hz)45
    Highest frequency (Hz)20000
    Power (W)50.0
    Number of ways2
    Number of loudspeakers2
    Speaker typePassive
    Speaker form factorOther
    Using a passive radiator, Dayton Audio's IO65XT speakers are equally well suited for indoor and outdoor use. They can be powered by a 70/100V...
