DAYTON AUDIO IO8XTB Speaker Indoor / Outdoor 2 Ways with Passive Radiator IP66 80W Black (Unit)
Using a passive radiator, Dayton Audio's IO8XT speakers are equally suited to indoor and outdoor use. They can be powered by a 70/100V amplifier for commercial installations or by an 8Ω amplifier for consumer use. A selector switch makes it quick and easy to choose an option to suit your use.
Reference : 17864
219,00 €tax incl.
182,50 € tax excl.
This product is temporarily unavailable.
Dayton Audio IO8XTB
Dayton Audio IO65XTB Enceintes Intérieur / Extérieur 2 Voies avec Radiateur Passif IP66 50W
This model is capable of producing extended bass using a passive radiator for deep, punchy bass reproduction. The top end of the audio spectrum is reproduced using a 1" silk dome tweeter, offering fine precision in the midrange and treble.
What's more, the IP66 protection rating and ABS chassis of these loudspeakers make them ideal for outdoor use, as they will not be affected by the elements or adverse weather conditions.
The IO8XT are supplied with brackets for vertical or horizontal mounting, and can be rotated for quick, easy and practical installation.
Dayton Audio IO8XTW
Dayton Audio IO8XTW Enceintes Intérieur / Extérieur 2 Voies avec Radiateur Passif
Product typePassive speaker
Power handlingRMS : 80W @ 8Ω
Max : 160W @ 8Ω
Frequency response38Hz - 20kHz
Impedance8Ω
SPL87dB 2.83V/1m
LoudspeakersPassive radiator 8"
Silk dome tweeter 1"
Protection classIP66
Dimensions38*25*24cm
Weight6.3kg
QuantityUnit
Impedance (Ω)8
Efficiency / Sensitivity (dB)87.0
Lowest frequency (Hz)38
Highest frequency (Hz)20000
Power (W)80.0
Number of ways2
Number of loudspeakers2
Speaker typePassive
Speaker form factorOther
Using a passive radiator, Dayton Audio's IO8XT speakers are equally suited to indoor and outdoor use. They can be powered by a 70/100V...
