Bookshelf Speakers 2 Way 40W 4 Ohm 84dB 60Hz-20kHz (Pair)
The Dayton Audio MK402X 2-way bookshelf loudspeakers offer excellent sound reproduction, thanks in particular to the integration of a crossover filter that delivers high frequencies with softness and flexibility.
Each loudspeaker is composed of a dome tweeter and a woofer to reproduce a wide range of frequencies. All the components are integrated in a textured black box with a geometric design of the most beautiful effect.
The Ø1.9cm (0.75") diameter silk dome tweeter on the MK402X provides soft, airy highs for a delicate, non-aggressive sound. Since sound waves are widely dispersed by this tweeter, it promotes a wide and realistic sound stage.
The Ø10.2cm (4") diameter woofer built into each MK402X is capable of delivering low frequencies up to 60Hz. The frequency response of this woofer is also uncut, allowing it to unveil beautiful low-midrange/midrange, for a deep and coherent reproduction.
The integrated crossover filter provides soft sound reproduction for listening sessions without auditory fatigue. Incorporating 7 components, the crossover uses asymmetrical slopes to combine the two speakers in a very musical way. It also flattens the high-frequency response curve for smoother sound.
" Somehow the designer managed to deal with the compromises just right to create a speaker that produces a very good experience with equalization. Overall, I am going to recommend the Dayton MK402X. If you need a pair of speakers that can excite you with well recorded music most of the time and not cost more than a dinner, you have found it. "
Product type | Bookshelf speakers |
Number of ways | 2 |
Bass-Reflex | |
Speaker drivers | 1x Treated-paper woofer Ø10.2cm (4") with 4 layer voice coil 1x Silk dome tweeter Ø1.9cm (0.75") with ferrofluid cooling |
Input impedance | 4 Ohm |
Power handling | RMS : 40W Max : 80W |
Frequency response | 60Hz - 20000Hz |
Sensitivity | 84dB 1W/1m |
Crossover | 3.3kHz Third order high-pass Second order low-pass (asymmetrical slopes) |
Connectors | Speaker terminals (compatible with banana plugs) |
Port tuning | 50Hz |
Color | Black |
Dimensions | 5-3/4" x 9-1/2" x 6-5/8" 14.6 x 24.1 x 16.8cm |
Weight | 10.3lbs. 4.7kg |
Quantity | Sold by pair |
Color | Black |
Impedance (Ω) | 4 |
Efficiency / Sensitivity (dB) | 84.0 |
Lowest frequency (Hz) | 60 |
Highest frequency (Hz) | 20000 |
Power (W) | 40.0 |
Number of loudspeakers | 2 |
Speaker type | Passive |
Speaker form factor | Bookshelf speaker |
