Dayton Audio VS8 Subwoofer Flat 20cm
This subwoofer was designed to compensate for the lack of space for modern audio installations for the home.
The VS8 can be installed permanently on walls, floors or ceilings or even behind a sofa, under a table, or nestled in a corner.
On the performance side, a 20cm long-range bass reflex uses a flared port to produce much more bass than would be expected from such a small case.
It features a brushed aluminum-look vinyl finish, and rubber feet that lift and protect the surfaces.
Thus, this subwoofer, due to its very modern design and technical prowess, proves to be the subwoofer essential for a home theater installation.
Features:
Color | Black |
Impedance (Ω) | NC |
Diaphragm type | N/A |
Efficiency / Sensitivity (dB) | N/A |
Max Linear Excursion (Xmax) (mm) | N/A |
Lowest frequency (Hz) | N/A |
Highest frequency (Hz) | N/A |
Power (W) | 120.0 |
Number of ways | 1 |
Number of loudspeakers | 1 |
