DAYTON AUDIO WP65BT 2-Way Speakers Indoor/Outdoor ABS IPP55 2x40W 8Ω 60Hz-20kHz Black (Pair)
This pair of Dayton Audio WP65BT speakers is designed for both indoor and outdoor use. These 2-way passive speakers feature a Ø15cm PP (polypropylene) woofer and a Ø2.5cm fabric tweeter. The outer shell is made of ABS, a weather-resistant plastic (IPP55). Three mounting options are available: wall-mounted, suspended, or landscaped with stakes.
By buying this product you get 23 loyalty points
Reference : 18234
239,00 €tax incl.
199,17 € tax excl.
This product is temporarily unavailable.
Dayton Audio WP65BT
2-way Speakers Indoor/Outdoor ABS IPP55 2x40W @8Ω 60Hz-20kHz Black (Pair)
Dayton Audio WP65BT 2-way Speakers Indoor/Outdoor ABS IPP55 2x40W @8Ω 60Hz-20kHz Black (Pair)
This pair of Dayton Audio WP65BT speakers is designed for both indoor and outdoor use. These 2-way passive speakers feature a Ø15cm PP (polypropylene) woofer and a Ø2.5cm fabric tweeter. The outer shell is made of ABS, a weather-resistant plastic (IPP55). Three mounting options are available: wall-mounted, suspended, or landscaped with stakes. In terms of performance, these speakers have a power handling capacity of up to 2x40Wrms, and incorporate a 70V/100V transformer with 8 ohm bypass. The loudspeakers deliver quality sound reproduction whatever the mounting method or environment chosen. They are suitable for both commercial and home use; gardens, patios, swimming pools, bars, restaurants, stores, etc.
Three different mounting modes
Wall mounting
Thanks to a ball joint, you can choose to mount these speakers on a vertical or horizontal axis, depending on the desired effect.
Suspended mounting
With the supplied screw ring, you can easily hang these speakers from a chain or rope.
Landscape mounting with stakes
Stake-mounted landscape brackets with integral ball joints provide solid support for these loudspeakers.
Product typeSpeakers indoor/outdoor
Ingress protection ratingIP55
Power handling2x40Wrms @ 8Ω
2x80W @ 8Ω (Max.)
Loudspeakers typeWoofer : Ø15cm, PP (polypropylene)
Tweeter : Ø2.5cm, fabric
Frequency response60Hz - 20kHz
Impedance8Ω / 70V / 100V
70VNC, 20, 10, 5, 2,5W
100VNC, 40, 20, 10, 5W
Sound pressure level (SPL)87dB / 88dB @ 8Ω, 2.83V/1m setting
Mounting typesWall mount / Pendant mount / Landscape mount
Landscape stake dimensionsØ6.35cm x 19.6cm
Wall mount dimensionsØ6.35cm x 8.90cm (4 screw holes)
Pendant mount support dimensionsØ20.32cm (8 screw holes)
DimensionsØ20*24.75cm
Weight4.54kg/speaker
Package2* Dayton Audio Speaker WP65BT
2* Landscape stakes
2* Wall mount
2* Suspension ring
Screws
Impedance (Ω)8
Efficiency / Sensitivity (dB)88.0
Efficiency / Sensitivity (dB)87.0
Lowest frequency (Hz)60
Highest frequency (Hz)20000
Power (W)40.0
Number of ways2
Number of loudspeakers2
Speaker typePassive
Speaker form factorWall / in-wall speaker
Speaker form factorOther
This pair of Dayton Audio WP65BT speakers is designed for both indoor and outdoor use. These 2-way...
