DYNAUDIO EMIT 10 Bookshelf Speakers 2-Way 85dB 52Hz-35kHz White (Pair)
The Dynaudio EMIT 10 are compact two-way stand-mountable speakers. This model is therefore ideal for small to medium-sized rooms. They are equipped with a 14cm MSP (Magnesium Silicate polymer) bass/midrange woofer and a 28mm Cerotar tweeter. In terms of performance, they are capable of reproducing a powerful, rich and detailed sound. This pair of speakers offers great performance in both hi-fi and home theater configurations.
By buying this product you get 72 loyalty points
Reference : 17620
729,00 €tax incl.
607,50 € tax excl.
Shipping date: 24-04-2025.
DYNAUDIO EMIT 10
Bookshelf Speakers 2-Way 85dB 52Hz - 35kHz White (Pair)DYNAUDIO EMIT 10 Bookshelf Speakers 2-Way 85dB 52Hz - 35kHz White (Pair)
14cm MSP Speaker
The EMIT 10 is equipped with a dual-magnet MSP driver for bass and midrange. This feature provides greater control and higher sensitivity. Thus, the MSP driver of the Dynaudio EMIT 10 provides a wide frequency response (52Hz - 35Khz) while ensuring a beautiful clarity on the midrange, all without distortion even at high volume.
28mm Cerotar Tweeter
The Cerotar tweeter of the EMIT 10 has a diameter of 28mm, larger than the usual tweeters. This soft dome model is made of fabric and a DSP coating (Dynaudio Secret Recipe). It allows a detailed and powerful reproduction of the treble, without generating hearing fatigue during long listening sessions. Moreover, the presence of the Hexis feature optimizing the air flow allows to keep a pure sound by limiting the distortions and the undesirable resonances while offering a more detailed sound.
Hybrid Crossover
Dynaudio has chosen to use two distinct circuits to reproduce the incoming sound signal. A first order filter for the high frequencies and a second order filter for the bass and midrange. This drastically improves the performance of the EMIT 10 in terms of sound reproduction. In addition, this feature allows you to combine the EMIT 10 with other models in the range while maintaining optimal tonal consistency.
Classic and practical connectors
On its rear face, the Dynaudio EMIT 10 have a screw terminal block allowing the speakers to receive 4mm banana plugs, spades or even stripped high-section cables.
A powerful design and a solid case
These Dynaudio speakers benefit from a Bass-Reflex design. The speaker housing is made of 18mm thick MDF and come with magnetic grille. Many internal reinforcements are also present inside the housing as well as a damping coating eliminating interferences and vibrations.
Product typeBookshelf speakers
Number of ways2
Bass ReflexFacing backwards
Bass/Medium speaker diameterØ140mm
Tweeter diameterØ28mm
Frequency response52Hz - 35kHz (±6dB)
Nominal impedance6Ω
Sensitivity85dB (2.83 V/1m)
Crossover frequency3700kHz
Crossover topologyTweeter : 1st order filter
Woofer : 2nd order filter
Power rating (IEC)150W
Dimensions (W*D*H)170*271.5*290mm
Weight6.43kg
ColorWhite
ColorWhite
Impedance (Ω)6
Efficiency / Sensitivity (dB)85.0
Lowest frequency (Hz)52
Highest frequency (Hz)35000
Power (W)150.0
Number of ways2
Number of loudspeakers2
Speaker typePassive
Speaker form factorBookshelf speaker
The Dynaudio EMIT 10 are compact two-way stand-mountable speakers. This model is therefore ideal for small to medium-sized rooms. They are equipped...
