By buying this product you get 149 loyalty points
The Dynaudio EMIT 30 speakers, big sisters of the EMIT 10 and EMIT 20, are a rather compact model for a column format. They are high-performance 2.5-way speakers. An ideal model for medium to large rooms. They are equipped with two 14cm MSP (Magnesium Silicate polymer) drivers. The first MSP takes care of the midrange and bass while the second one concentrates on the reproduction of the low frequencies, allowing to fill large spaces. They are accompanied by a 28mm Cerotar tweeter providing a detailed and accurate sound. The EMIT 30s are capable of delivering powerful, rich, dynamic and transparent sound. They offer superb performance in both hi-fi and home theater configurations. Whether used as a stand-alone stereo pair or in a 5.1-channel (or higher) home theater configuration, their sonic performance will impress you.
The EMIT 30 is equipped with a dual-magnet MSP driver for bass and midrange and a second MSP driver exclusively for bass. The dual-magnet MSP material offers greater motion control and higher sensitivity. The diaphragm is bonded directly to the voice coil, which allows for particularly precise and smooth control. Thus, the MSP drivers of the Dynaudio EMIT 30 provide a wide frequency response (39Hz - 35Khz) while maintaining a beautiful clarity in the midrange, all without distortion even at high volume.
The Cerotar tweeter of the EMIT 30, like that of the EMIT 10 and the EMIT 20, has a diameter of 28mm, a larger diameter than the usual tweeters. This soft dome unit is made of fabric and DSP (Dynaudio Secret Recipe) coating. It allows a detailed and powerful restitution of treble without tiring your hearing over a long period of listening. In addition, the presence of the Hexis system optimizing the airflow makes it possible to keep a pure sound by limiting distortions and unwanted resonances while giving more details to the sound.
Dynaudio has chosen to use several circuits to effectively reproduce the incoming sound signal. A first order filter for the high frequencies and a second order filter for the bass and midrange. This drastically increases the performance of the EMIT 30 in terms of sound quality. Moreover, this particularity makes it possible to associate this model with other speakers of the range while maintaining an optimal tonal coherence. The cut-off frequencies of these filters are located at 1000Hz and 3550Hz.
On their rear side, the Dynaudio EMIT 30 have a screw terminal allowing the speakers to receive 4mm banana plugs, forks or stripped cables of strong section.
These Dynaudio speakers benefit from a Bass-Reflex system with two double flared vents. The chassis of the speakers is made of 18mm thick MDF. Each speaker comes with a magnetic grille to protect the drivers. Numerous internal reinforcements are also present inside the chassis, as well as a damping coating to eliminate interference and vibrations.
Product type | Column speakers |
Number of ways | 2.5 |
Bass Reflex | Facing backwards |
Bass speaker diameter | Ø140mm |
Bass/Medium speaker diameter | Ø140mm |
Tweeter diameter | Ø28mm |
Frequency response | 39Hz - 35kHz (±6dB) |
Impedance | 4Ω |
Sensitivity | 87dB (2.83V/1m) |
Crossover frequency | 1000Hz 3800Hz |
Crossover topology | Tweeter: 1st order filter Woofer: 2nd order filter |
Power rating (IEC) | 180W |
Dimensions (W*D*H) | 170*271.5*900mm |
Weight | 15.53kg |
Color | Black |
Color | Black |
Impedance (Ω) | 4 |
Efficiency / Sensitivity (dB) | 87.0 |
Lowest frequency (Hz) | 39 |
Highest frequency (Hz) | 35000 |
Power (W) | 180.0 |
Number of loudspeakers | 3 |
Speaker type | Passive |
Speaker form factor | Tower speaker |
