By buying this product you get 79 loyalty points
3-ways speakers Bass-Reflex 200W 90dB 40Hz - 22kHz Design Vintage Walnut (pair)
The Eltax Monitor MTR 1959 with their vintage look is inspired by the most beautiful speakers of the 70s. This 3 ways Bass-Reflex model features a 30cm bass speaker, a 12-cm medium speaker and a high-pitched speaker for balanced, rich sound and deep, generous bass. The compact size makes them perfect speakers to fit into a small living room.
Its 30cm loudspeaker, whose membrane is made of cellulose pulp, allows to move a large mass of air while combining stiffness and lightness. It can therefore seek very low frequencies while rendering the sound in a reactive and dynamic way. In addition, this speaker is loaded with Bass-Reflex, which allows it to extend its response to a frequency of 40Hz and deliver powerful and deep bass while remaining natural.
A 25mm diameter dome Tweeter and a central warhead in a compression chamber allow a homogeneous and precise high frequency reproduction. It is the central warhead mechanically amplifying the yield that allows this very clean diffusion of the treble. In addition, the medium speaker brings a rich and natural sound to the Eltax Monitor MTR 1959.
The Eltax Monitor MTR 1959 adopts a robust cabinetry with its reinforced MDF cases recalling in an elegant way the aesthetics of the 70s. Its dimensions of 38cm wide and 60cm high make them relatively compact speakers and facilitate their integration into any type of interior. Technically, many internal reinforcements will also be found to limit and remove harmful vibrations. In addition, the inclined supports of the speakers optimize the phase and the perception of the different frequencies. The vent leading to the front of the enclosure supporting the bass-reflex reduces the necessary spacing of the enclosures with a rear wall and facilitates their placement in a room. Finally, heavy section cables, banana plugs and forks are compatible with the screw terminals of the Eltax Monitor 1959 enclosure.
Product type | Speakers |
System type | 3 Ways Bass-Reflex |
Power | 200W |
Woofer | Ø30cm with a membrane made of cellulose pulp |
Medium | Ø12cm, with a membrane made of cellulose pulp |
Tweeter | Ø25mm, with a central warhead in a compression chamber |
Frequency response (±4dB) | 40Hz - 22kHz |
Sensitivity | 90dB |
Impedance | 5-8Ω |
Dimensions (LxPxH) | 380 x 600 x 302mm |
Net weight | 17,7kg (Unit) |
Color | Walnut |
Color | Walnut |
Impedance (Ω) | 8 |
Efficiency / Sensitivity (dB) | 90.0 |
Lowest frequency (Hz) | 40 |
Highest frequency (Hz) | 22000 |
Power (W) | 200.0 |
Number of ways | 3 |
Number of loudspeakers | 3 |
Speaker type | Passive |
Speaker form factor | Other |
