By buying this product you get 99 loyalty points
The Eltax Monitor PWR 1959 with their vintage look are inspired by the finest loudspeakers of the 70s. Two 25mm dome tweeters ensure the retransmission of a balanced and rich sound as well as deep and generous bass. This model highlights the bass thanks to their impactful and powerful transcription while remaining natural.
Its 38cm loudspeaker, whose membrane is made of cellulose pulp, makes it possible to move a large mass of air while combining rigidity and lightness. It can therefore go for very low frequencies while restoring the sound in a reactive and dynamic way. In addition, this loudspeaker is loaded with Bass-Reflex, which allows it to extend its response up to a frequency of 30Hz and deliver powerful, deep and realistic bass.
Two 25mm diameter dome tweeters as well as a central warhead in a compression chamber allow a homogeneous and precise reproduction of high frequencies. It is the central ogive mechanically amplifying the output which allows this very clean diffusion of the treble. In addition, the midrange driver gives the Eltax Monitor MTR 1959 a rich and natural sound on the midrange.
The Eltax Monitor PWR 1959 adopt a robust cabinetwork with its reinforced MDF boxes elegantly reminiscent of the aesthetics of the 70s. Its dimensions of 51.8cm wide and 90cm high made them relatively impressive speakers. Technically speaking, there are also many internal reinforcements to limit and eliminate harmful vibrations. In addition, the inclined supports of the speakers optimize the phase and the perception of the different frequencies. The two vents opening on the front face of the speaker supporting the bass-reflex reduce the spacing of the speakers necessary with a rear wall and facilitate their placement in a room. Finally, the large section cables, the banana plugs and the forks are compatible with the screw terminals of the Eltax Monitor 1959 loudspeaker.
Product type | Passive speakers |
System type | 3-way / Bass-Reflex (2x front vent) |
Effective power | 30-250W |
Bass-speaker (Woofer) | Ø38cm, cellulose pulp membrane |
Medium speaker | Ø16cm, cellulose pulp membrane |
Tweeters | 2x Ø25mm, dome with central ogive and acoustic pavilion |
Frequency response (±4dB) | 30Hz - 22kHz (+/- 3 dB) |
Sensibility | 96dB |
Impedance | 5-8Ω |
Dimensions (LxPxH) | 518 x 900 x 385 mm |
Net weight | 34kg (Unit) |
Color | Walnut |
Color | Walnut |
Impedance (Ω) | 8 |
Impedance (Ω) | 5 |
Efficiency / Sensitivity (dB) | 96.0 |
Lowest frequency (Hz) | 30 |
Highest frequency (Hz) | 22000 |
Power (W) | 250.0 |
Number of ways | 3 |
Number of loudspeakers | 3 |
Speaker type | Passive |
Speaker form factor | Other |
