MARTIN LOGAN MOTION FOUNDATION B2 Bookshelf Speakers Walnut
The Martin Logan Motion Foundation B2 speaker is the largest model in this range. A model capable of delivering impressive sonic detail and dynamic range.
By buying this product you get 109 loyalty points
Reference : 18934
1 090,00 €tax incl.
908,33 € tax excl.
Martin Logan Motion Foundation B2 Bookshelf Speakers 2 Ways 100W 5 Ohm 42Hz - 23kHz Walnut (Pair)
Martin Logan Motion Foundation B2: 3/4 view
The S Gen2 Obsidian Folded Motion tweeter, Folded Motion waveguide and 6.5" aluminum-membrane bass/midrange driver work together to create a stunning and impressive experience with perfectly defined highs and deep bass, while maintaining a compact footprint.
The Martin Logan Foundation range
The Martin Logan Foundation range redefines accessibility by integrating several of Martin Logan's renowned high-performance technologies, all at an affordable price. Drawing on 40 years of design and technical prowess, and offering incredible performance, the Foundation range represents an excellent gateway to the world of HiFi. It's the ideal foundation for a highly efficient stereo or surround sound system.
Martin Logan loudspeakers are renowned for their exceptional articulation, detail and realism, whatever the listening environment. Using advanced driver and controlled dispersion technologies, Martin Logan offers a unique listening experience.
Martin Logan Motion Foundation B2 : Tweeter
Martin Logan Motion Foundation B2 : Tweeter S Gen2 Obsidian Folded Motion
The Gen2 Obsidian Folded Motion tweeter delivers incredible sonic performance, unmatched by conventional technologies. By folding an ultra-thin material, Martin Logan is able to increase the emissive surface area in a small space. Large surface area, low weight and low excursion mean an incredibly fast and responsive tweeter, capable of reproducing the most nuanced content with stunning detail and clarity.
Martin Logan Motion Foundation B2 : Folded Motion Waveguide
Le waveguide des Martin Logan Foundation B2 assure une parfait contrôle de la dispersion du tweeter, couvrant la zone d'écoute avec des détails et une précision incroyables. Celui-ci évite également les réflexions de la pièce qui nuisent aux performances et fournit un son plus cohérent sur une zone d'écoute plus large.
Martin Logan Motion Foundation B2 : Waveguide du tweeter
Martin Logan Motion Foundation B2: Bass-midrange driver
Martin Logan Motion Foundation B2: bass-midrange driver with aluminum cone
Using technology from Martin Logan's Motion XT and Motion ranges, the B2s take advantage of the exceptional properties of the aluminum diaphragm to maximize mid-bass driver clarity, detail and efficiency.
Martin Logan Motion Foundation B2: Surprisingly compact
Martin Logan Motion Foundation B2: Dimension diagram
Product typeBookshelf speakers
Number of ways2
Frequency response43Hz - 23kHz
Tweeter dispersion90° (vertical) x 90° (horizontal)
Sensitivity90dB
Impedance5Ω
Crossover frequency3800Hz
Tweeter dimensions2.54 x 2.39cm
Midbass driver dimensionsØ16.5cm
Midbass driver materialsAluminum cone
Cast aluminium salad frame
Bass-reflexRear port
Power handling15 - 100W
Dimensions (W x D x H)19.68 x 29.18 x 38.12cm
Weight6.8kg / unit
ColorWalnut
PackagePair
ColorWalnut
ColorWood
Impedance (Ω)5
Efficiency / Sensitivity (dB)90.0
Lowest frequency (Hz)42
Highest frequency (Hz)23000
Power (W)100.0
Number of ways2
Number of loudspeakers2
Speaker typePassive
Speaker form factorBookshelf speaker
MARTIN LOGAN MOTION FOUNDATION B2 Bookshelf Speakers 2 Ways 100W 5 Ohm 42Hz - 23kHz Walnut (Pair)
The Martin Logan Motion Foundation B2 speaker is the largest model in this range. A model capable of delivering impressive sonic detail and dynamic...
