By buying this product you get 276 loyalty points
The flagship of the Motion Foundation range, the Martin Logan Foundation F2 speaker offers excellent sound performance in a floorstanding design. For those seeking the most dynamic listening experience, floorstanding speakers are the ideal choice. The F2 combines the Folded Motion S Gen2 Obsidian tweeter with 3 custom-designed 6.5" aluminum cone woofers.
The Martin Logan Foundation range redefines accessibility by integrating several of Martin Logan's renowned high-performance technologies, all at an affordable price. Drawing on 40 years of design and technical prowess, and offering incredible performance, the Foundation range represents an excellent gateway to the world of HiFi. It's the ideal foundation for a highly efficient stereo or surround sound system.
Martin Logan loudspeakers are renowned for their exceptional articulation, detail and realism, whatever the listening environment. Using advanced driver and controlled dispersion technologies, Martin Logan offers a unique listening experience.
The Gen2 Obsidian Folded Motion tweeter delivers incredible sonic performance, unmatched by conventional technologies. By folding an ultra-thin material, Martin Logan is able to increase the emissive surface area in a small space. Large surface area, low weight and low excursion mean an incredibly fast and responsive tweeter, capable of reproducing the most nuanced content with stunning detail and clarity.
Le waveguide des Martin Logan Foundation F2 assure une parfait contrôle de la dispersion du tweeter, couvrant la zone d'écoute avec des détails et une précision incroyables. Celui-ci évite également les réflexions de la pièce qui nuisent aux performances et fournit un son plus cohérent sur une zone d'écoute plus large.
Using technology from Martin Logan's Motion XT and Motion ranges, the F2s take advantage of the exceptional properties of the aluminum diaphragm to maximize mid-bass driver clarity, detail and efficiency.
Product type | Floorstanding speakers |
Number of ways | 3 |
Frequency response | 36Hz - 23kHz |
Tweeter dispersion | 90° (vertical) x 90° (horizontal) |
Sensitivity | 92dB |
Impedance | 4Ω |
Crossover frequency | 330Hz 3600Hz |
Tweeter dimensions | 2.54 x 2.39cm |
Midbass driver dimensions | Médium : 1x Ø14cm Basses : 3x Ø16.5cm |
Midbass driver materials | Aluminum cone Cast aluminium salad frame |
Bass-reflex | 2x Rear ports |
Power handling | 15 - 200W |
Dimensions (W x D x H) | 22.22 x 40.69 x 112.8cm |
Weight | 23.81kg / unit |
Color | Walnut |
Color | Wood |
Color | Walnut |
Impedance (Ω) | 4 |
Efficiency / Sensitivity (dB) | 92.0 |
Lowest frequency (Hz) | 36 |
Highest frequency (Hz) | 23000 |
Power (W) | 200.0 |
Number of loudspeakers | 5 |
Speaker type | Passive |
Speaker form factor | Tower speaker |
