By buying this product you get 23 loyalty points
A considerable soundstage for very compact speakers
The 3010i speakers remain faithful to the front profile Qacoustic (an acoustically optimal form) but this times gains height and 25% more depth than its predecessors.
This increase in internal volume allows to naturally strengthen the frequency response in the bass. These speakers are therefore able to produce a massive sound with a strong presence, despite an extremely compact design.
This change in format also reduces unwanted noise associated with the resonance of the room as this limits the potential noise reflected from the rear wall, which can be more easily absorbed by the membrane of the speaker.
The traditional terminal blocks were replaced with low profile brackets.
This not only increases the strength and durability of connectors. These partly internal sockets also allow deep connections while leaving the possibility to position the speaker close to a wall (including with 4mm banana plugs).
We can therefore use smooth banana plugs, pins or bare son at one's convenience.
Type well | Reflex 2-way |
Low Driver | 100mm |
High Driver | 22mm |
Frequency Response (+ 3dB, 6dB) | 65Hz - 30kHz |
nominal impedance | 6 Ω |
minimum impedance | 4 Ω |
Sensitivity (2.83 Vrms @ 1m) | 86 dB |
recommended power | 15-75W |
Transition Frequency | 2.6kHz |
Volume | 4.0 L (244 cu in) |
Dimensions | 150 x 253 x 252 mm |
Weight (for each speaker) | 4.1 kg |
Color | Gray |
Color | Black |
Impedance (Ω) | 4 |
Impedance (Ω) | 6 |
Efficiency / Sensitivity (dB) | 86.0 |
Lowest frequency (Hz) | 65 |
Highest frequency (Hz) | 30000 |
Power (W) | 75.0 |
Number of ways | 2 |
Number of loudspeakers | 2 |
Speaker type | Passive |
Speaker form factor | Bookshelf speaker |
