Q Acoustics 3020i Bookshelf speaker Graphite Black (Pair)
The Q 3020I inheritsthe qualities of its predecessors (Q3020, multiple award winner). This new version uses a 125mm bass motor and a 22mm treble motor to produce a rich sound that can fill a room while retaining rich, nuanced and deep. For convenience, they can be installed on surfaces, stand or wall mounted.
Reference : 12821
299,00 €tax incl.
249,17 € tax excl.
Very compact speakers providing considerable soundstage
Q-acoustic speakers 3020i
Technology to improve the width of the sound stage
Speakers Q3020i
In its new version, the Q3020i cabinet incorporates a bracing point to point . The latter, as well as fasteners are extremely rigid and stable which promotes good development of the stereo image and precision in the soundstage.
The tweeters are now decoupled from the low frequency circuit via a control unit in order to significantly reduce interference and to further increase the stability of restitution.
A powerful and massive sound
Q acoustics Q3020i
If this model retains the acoustically optimal form fit for Q3 series, the camera body evolves in height and depth to earn almost 25% more space. Increased volume favoring the frequency response of bass and further strengthening the excellent size / power ratio which the series has become renowned. It is not uncommon to be surprised to discover that these speakers produce a considerable innatendu and sound, given their size.
Strong and high compatibility connectors
Connectors Q acoustics 3020 i
The traditional terminal blocks were replaced with low profile brackets.
This not only increases the strength and durability of connectors. These recessed fasteners also allow deep connections while leaving the possibility to position the speaker close to a wall (including with 4mm banana plugs).
We can therefore use smooth banana plugs, pins or bare son at his convenience.
Test des Q Acoustics 3020i par On-Mag
" The Q Acoustics 3020i sends out big sound. They have a dynamic, cheerful and generous personality. Their stereophonic image has beautiful dimensions and with them, we are not bored. "
Type wellReflex 2-way
low engine125mm
acute motor22mm
Frequency Response (+ 3dB, 6dB)64Hz - 30kHz
nominal impedance6 Ω
minimum impedance4 Ω
Sensitivity (2.83 Vrms @ 1m)88 dB
recommended power25-75W
Transition Frequency2.4kHz
Volume6.1 L (372 cu in)
Dimensions170 x 278 x 282 mm
Weight (for each speaker)5.5 kg
ColorGray
Impedance (Ω)4
Impedance (Ω)6
Efficiency / Sensitivity (dB)88.0
Lowest frequency (Hz)64
Highest frequency (Hz)30000
Power (W)75.0
Number of ways2
Number of loudspeakers2
Speaker typePassive
Speaker form factorBookshelf speaker
2 reviews
Attention
Ces enceintes de bonne facture ne se marient pas avec tous les amplis vu leur rendement.
Il leur faut un amplificateur avec du jus pour pouvoir descendre en dessous de 4 ohms.
Dans mon cas un peu déçu, car c'était pour accompagner une TV a travers l'ampli.
This review has been posted for Q Acoustics 3020i Bookshelf speaker Graphite Black (Pair)
Superbe écoute
Une enceinte bibliothèque relativement petite avec un son ample, très équilibré. Les instruments se distinguent très finement et les basses sont vraiment généreuses pour un aussi petit volume. Je suis enchanté de cet achat. Quelle différence avec les précédentes enceintes (des Philips sans interet). J'ai également de grosses enceintes Monitor Audio III et on pourrait presque croire qu'elles jouent dans la même cours. Pour une pièce de taille moyenne (pour moi 25m2) c'est très réussi. Vous ne regretterez pas.
The Q 3020I inheritsthe qualities of its predecessors (Q3020, multiple award winner). This new version uses a...
