Very compact speakers providing considerable soundstage
In its new version, the Q3020i cabinet incorporates a bracing point to point . The latter, as well as fasteners are extremely rigid and stable which promotes good development of the stereo image and precision in the soundstage.
The tweeters are now decoupled from the low frequency circuit via a control unit in order to significantly reduce interference and to further increase the stability of restitution.
If this model retains the acoustically optimal form fit for Q3 series, the camera body evolves in height and depth to earn almost 25% more space. Increased volume favoring the frequency response of bass and further strengthening the excellent size / power ratio which the series has become renowned. It is not uncommon to be surprised to discover that these speakers produce a considerable innatendu and sound, given their size.
The traditional terminal blocks were replaced with low profile brackets.
This not only increases the strength and durability of connectors. These recessed fasteners also allow deep connections while leaving the possibility to position the speaker close to a wall (including with 4mm banana plugs).
We can therefore use smooth banana plugs, pins or bare son at his convenience.
" The Q Acoustics 3020i sends out big sound. They have a dynamic, cheerful and generous personality. Their stereophonic image has beautiful dimensions and with them, there is no boredom. "
Type well | Reflex 2-way |
low engine | 125mm |
acute motor | 22mm |
Frequency Response (+ 3dB, 6dB) | 64Hz - 30kHz |
nominal impedance | 6 Ω |
minimum impedance | 4 Ω |
Sensitivity (2.83 Vrms @ 1m) | 88 dB |
recommended power | 25-75W |
Transition Frequency | 2.4kHz |
Volume | 6.1 L (372 cu in) |
Dimensions | 170 x 278 x 282 mm |
Weight (for each speaker) | 5.5 kg |
Color | Walnut |
Impedance (Ω) | 4 |
Impedance (Ω) | 6 |
Efficiency / Sensitivity (dB) | 88.0 |
Lowest frequency (Hz) | 64 |
Highest frequency (Hz) | 30000 |
Power (W) | 75.0 |
Number of ways | 2 |
Number of loudspeakers | 2 |
Speaker type | Passive |
Speaker form factor | Bookshelf speaker |
