Q ACOUSTICS 3030i Bookshelf Speaker 2 Way 88dB 46Hz - 30kHz Graphite Gray (Pair)
The Q Acoustics 3030i loudspeakers incorporate a large woofer/midrange driver inspired by the 3050i floorstanding speaker and a 25mm decoupled tweeter.  This combination provides a beautiful bass presence, balanced and expressive midrange and precise and detailed high frequencies.  This design will allow you to enjoy your music to the fullest and capture all its richness.
By buying this product you get 38 loyalty points
Reference : 14348
389,00 €tax incl.
324,17 € tax excl.
Q Acoustics 3030i
Enceintes bibliothèques 2 voies 88dB 46Hz - 30kHz Gris Graphite (La paire)
Dynamic & Detailed
The all-new woofer/midrange uses a high quality, impregnated, coated paper cone combined with an optimised motor. As this speaker is capable of a prodigious low frequency presence, the 22mm tweeter above it is decoupled and is therefore isolated from the vibration of the w/midrange driver, for a clearer and purer sound.
An extremely rigid body
Like the entire 3000i range, the 3030i uses the unique reinforcement technique developed by Q Acoustics. This computer-assisted precision process results in an extremely rigid speaker cabinet that eliminates unwanted vibrations.
Contemporary aesthetics of the most beautiful effect
The Q Acoustics 3030i, in addition to its sturdy structure, has a beautiful contemporary look with its Graphite Grey colour for the most beautiful effect. As with the other models in the 3000i range, the protective grilles are magnetic and each speaker is surrounded by a chrome ring.
Product typeBookshelf speaker
Number of ways2
Bass Reflex
Woofer diameterØ165mm (6.5")
Tweeter diameterØ22mm (0.9")
Frequency response (±3dB, -6dB)46Hz - 30kHz
Average impedance6Ω
Minimum impedance4Ω
Sensitivity (2.83V@1m)88dB
Stereo amplifier power25 - 75W
Crossover frequency2.4kHz
Effective volume12.5L
Dimensions (L x P x H)200 x 329 x 325mm
Weight6.4kg
ColorGraphite Gray
ColorGray
Impedance (Ω)4
Impedance (Ω)6
Efficiency / Sensitivity (dB)88.0
Lowest frequency (Hz)46
Highest frequency (Hz)30000
Power (W)75.0
Number of ways2
Number of loudspeakers2
Speaker typePassive
Speaker form factorBookshelf speaker
The Q Acoustics 3030i loudspeakers incorporate a large woofer/midrange driver inspired by the 3050i floorstanding speaker and a 25mm decoupled...
