By buying this product you get 39 loyalty points
Active Subwoofer 140W
The Subwoofer Q Acoustics 3070S is capable of delivering 140W RMS thanks to its two 170mm bass-medium speakers. This box, capable of moving from absolute silence to explosive power in an instant, will brilliantly accompany your favourite music or movies.
Like its predecessor known for its performance - the 2000 Series 2070Si - the 3070S uses a two-speaker system rather than a single speaker system to achieve superb sound depth. In addition, the Q Acoustics subwoofer incorporates a 140W amplifier perfectly adapted and calibrated to provide the 3070S with the power it needs.
With its 200mm width, the 3070S is capable of fitting into tight spaces, where the usual subwoofers would find it difficult to fit. The 3070S is actually even more compact than its predecessor, the 2070Si, while significantly improving its performance and design.
The 3070S is supplied with tips with rubber plates to ensure excellent stability and fit most surfaces.
Speaker type | Subwoofer |
Subwoofer type | Active |
Load type | Bass Reflex |
Subwoofer power | 140W RMS |
Loudspeakers type | 2x Grave-Medium 170mm |
Crossover frequency | 50 - 150Hz |
Color | Graphite black |
Max dimensions (with grille and spikes) | 200 x 425 x 535mm |
Min dimensions (without grille spikes) | 200 x 400 x 525mm |
Weight | 13.6kg |
Package | 1x 3070S Subwoofer 1x Magnetic Speaker Grille 1x User Manual 1x AC Power Cable 4x Adjustable Floor Spikes |
