The Q acoustics Concept 20 2-way loudspeaker systems offer unmatched quality in the world of Hifi. The Q Acoustics 2020i, the award-winning Q Acoustics 2020i, has been awarded with a high-precision industrial process by a double-wall MDF cabinet isolated from each other by a "Gelcore" damping gel of studied density in accordance with the bandwidth of the 125mm low midrange speaker.
energydeployed by the loudspeakers is thus absorbed by this gel sandwiched by the two walls. This simulation of vacuum allows a non-transmission of vibrations on the outer casing. The result is equal to the means deployed with rare readability reached on a pair of speakers still affordable.
Sothe Qacoustics Concept 20 astonishes by their dynamic capabilities, the precision of the sound image of great fidelity. Concept 20 libraries are suitable for listening to Hi-Fi music as well as home blockbuster.
This Pspeaker area is ideal for both wall and floor mounting.
In short, small but sturdy, these speakers have surprising the most demanding mixing audio message fidelity and high end finish!
Read the test bench of the Qacoustics Concept 20 speakers that received the
Color |
Impedance (Ω) |
Efficiency / Sensitivity (dB) |
Lowest frequency (Hz) |
Highest frequency (Hz) |
Power (W) |
Number of ways |
Number of loudspeakers |
