Q acoustics Concept 20 Bookshelf Speakers White (Pair)
Reference : 11989
499,00 €tax incl.
415,84 € tax excl.
Including 1,00 € for green tax
The Q acoustics Concept 20 2-way loudspeaker systems offer unmatched quality in the world of Hifi. The Q Acoustics 2020i, the award-winning Q Acoustics 2020i, has been awarded with a high-precision industrial process by a double-wall MDF cabinet isolated from each other by a "Gelcore" damping gel of studied density in accordance with the bandwidth of the 125mm low midrange speaker.
energydeployed by the loudspeakers is thus absorbed by this gel sandwiched by the two walls. This simulation of vacuum allows a non-transmission of vibrations on the outer casing. The result is equal to the means deployed with rare readability reached on a pair of speakers still affordable.
Sothe Qacoustics Concept 20 astonishes by their dynamic capabilities, the precision of the sound image of great fidelity. Concept 20 libraries are suitable for listening to Hi-Fi music as well as home blockbuster.
This Pspeaker area is ideal for both wall and floor mounting.
In short, small but sturdy, these speakers have surprising the most demanding mixing audio message fidelity and high end finish!
qacoustics Concept 20
Read the test bench of the Qacoustics Concept 20 speakers that received the
AWARDS 2014
Features:
  • Enclosure Type: Bass Reflex 2 way
  • Woofer: 125mm
  • Heavy-duty motor: 25mm
  • Frequency response: 64Hz - 22kHz
  • Nominal impedance: 6 ohm
  • Minimum impedance: 4 ohm
  • Sensitivity: 86 dB
  • Recommended power: 25 - 75w
  • Transition Frequency: 2.9 kHz
  • Dimensions H / W / W mm: 265 x 282 x 170
  • Weight: 12Kg
  • Sold by pair
The bundle contains:
  • 2 x enclosures libraries Concept 20
  • 2 x bass reflex foams
  • 1 x Cotton Cleaner for Speakers
  • 1 x manual
[img-23718-aft-thickbox_default]
Impedance (Ω)6
Impedance (Ω)4
Efficiency / Sensitivity (dB)86.0
Lowest frequency (Hz)64
Highest frequency (Hz)22000
Power (W)75.0
Number of ways2
Number of loudspeakers2
