RUARK AUDIO SABRE-R Bookshelf Speakers (Pair)
With the Sabre-R, Ruark Audio offers us a pair of 2-way bookshelf speakers with a power handling capacity of 100W, based on a 15cm diameter paper cone woofer and a 26mm diameter silk cone tweeter. Ruark Audio recommends using an amplifier with between 25 and 100W of power per channel at 6Ω.
By buying this product you get 79 loyalty points
Reference : 20039
790,00 €tax incl.
658,33 € tax excl.
Shipping date: 22-04-2025.
Ruark Audio Sabre-R 2-Way Bookshelf Speakers 100W 6Ω 50Hz-20kHz (Pair)
Ruark Audio Sabre-R : 3/4 view
Ruark Audio Sabre-R: Sophisticated aesthetics
With its Sabre-R speakers, Ruark Audio once again demonstrates its commitment to the aesthetics of its products. Handcrafted and finished in a walnut that is usually only found on quality furniture, these speakers have a discreetly elegant design that will fit in with both classic and contemporary interiors.
Ruark Audio Sabre-R : view in context
Ruark Audio Sabre-R : component details
Ruark Audio Sabre-R: Advanced technology
The Sabre-R speakers are as pleasing to the eye as they are to the ear, relying on a Ø15cm paper cone low-midrange driver and a Ø26mm silk cone tweeter with a crossover set at 2.2kHz. The Sabre-R also feature a bass reflex system with double flared port calibrated to 55Hz. Finally, each speaker has two gold-plated terminals, giving you access to bi-wiring or bi-amplification.
Product typeBookshelf speakers
Number of ways2
WooferØ150mm paper diaphragm
Tweeter driverØ26mm silk dome
Nominal impedance
Minimum impedance4.2Ω
Frequency response50Hz – 20KHz (±3dB)
Sensitivity86dB/W/m
Crossover2.2kHz
Power100W
Dimension290 x 175 x 215mm
Weight5kg/unit
FinishComposite walnut
ColorWood
PackageSold by pair
ColorWood
Impedance (Ω)6
Efficiency / Sensitivity (dB)86.0
Lowest frequency (Hz)50
Highest frequency (Hz)20000
Power (W)100.0
Number of ways2
Number of loudspeakers2
Speaker typePassive
Speaker form factorBookshelf speaker
RUARK AUDIO SABRE-R 2-Way Bookshelf Speakers 100W 6 Ohm 50Hz-20kHz (Pair)
With the Sabre-R, Ruark Audio offers us a pair of 2-way bookshelf speakers with a power handling capacity of 100W, based on a 15cm diameter paper...
