This "Audiophile" subwoofer has been designed around a high-end amplifier and speaker to radically transform your audio system.
Equipped with a Direct Servo technology and a common power, it is the indispensable complement to any system worthy of the name.
Focus on Direct-Servo technology:
- The effects of thermal compression are eliminated during normal operation.
- Enables greater efficiency that would normally require a more powerful amplifier.
- The extension of the sub-basses can be achieved by using a low-mass pilot with an unmatched transient response.
- Mechanical and thermal memory effects are reduced, which improves the transient response.
- The effective value Q of 0.3 allows a much tighter and more precise control than the conventional models.
- Maximum reduction of the bass feedback in the box.
Main Features :
- HP: 12 "(31 cm) high excursion driver with patented Direct Servo system
- Amplifier A370PEQ3 370W RMS Class A Servo B / Patented Controlled
- Frequency response: 14 to 200Hz (-2dB @ 14Hz) with LFE inputs in A370PEQ3 / XLR2 / XLR3
- Frequency response: 14 to 100Hz (-2dB @ 14Hz) with LINE IN inputs on all models
- Slope of recovery12 or 24dB / octave (PEQ and the XLR versions)
- Filter (Low Pass): 25 - 100Hz
- Filter (high pass): 20Hz 18dB / octave
- Phase phase response <90 ° to 20Hz
- Phase adjustment from 0 to 180 degrees - continuous variation
- (Q = 0.5), mean (Q = 0.7) and low (Q = 1.1)
- Finishes: Matt black oak
- Weight 28kg
Amplifier A370PEQ3
