Genuine Closed Subwoofer "Audiophile" featuring the revolutionary Direct Servo technology to channel the sounding resonant effects.
Equipped with an impeccable finish and with a common technology and power, it is the indispensable complement to any system worthy of the name.
Focus on Direct-Servo technology:
- Thethe effects ofcompressionthermalare eliminated in normal operation.
- allowsgreater efficiency Span>whowould normally require Span>a more powerful amplifier.
- Thethe extension of the lowbe made using a pilotof low masswithan unparalleled transient response.
- Theememory ffets Span>guyanic and thermalare reduced Span>, which improves the transient response. Span>
- The actual valueQ0.3allows controlmuch tighter Span>and more accurate than Span>conventional models. Span>
- maximumof thenegative feedback Span>of bassinside u caisson
Features:/ Strong>
- HP: Driver 12"(31 cm)high excursionwith patented Direct Servo system
- Amplifier Module: A370-XLR3(370W RMS)
- : Bowl and cone Aluminum, rubber suspension Span>
- Amplifier370WRMSClass AservoB/patented Span>control
- Dimensions15-3 / 4 "(L) x15-3 / 4 "(H)x17 "(D)-(18-1 / 2"Dwith grid)
- response Span>frequency: 14 to 200 Hz(-2dB@14 Hz)with entries Span>LFEinA370PEQ3 / XLR2 / XLR3
- response Span>frequency: 14 to 100 Hz(-2dB@14 Hz) withinputs LINE IN Span>on all models Span>
- Overlap slope of 12 or 24 dB / octave (PEQ and XLR versions )
- Filter ( Low Pass): 25 - 100 Hz
- Filter ( high pass): 20Hz 18 dB / octave
- Phase phase response <90 degrees at 20 Hz
- Phase adjustment from 0 to 180 degrees - continuous variation
- F low damping actor: high parameters (Q = 0.5), means (Q = 0.7) and low(Q= 1.1)
- Finishes: Span>Black oak matt Span>
- Weight: 28kg
P>
P>
P>
P>
P>
Amplifier A370-XLR3
P>
PDF Manufacturer
