Swans M10 HiFi - 2.1 Hi-Fi Speakers Kit Strong>
The Swans M10 is a 3-way 2.1 kit for multimedia use.
All the caissons are made of wood to obtain a good resonance, and therefore sonorité
The 2-way satellites are closed and composed of a medium of 8cm and a dome tweeter textile.
The case uses a 13cm long excursion loudspeaker, as well as 2 bass-reflex vents. P>
This kit is shielded, so as not to interact with a CRT screen.
Swans M10 | ||
subwoofer | ||
Series: | Swans 2.1 Multimedia Speaker | |
System Type: | 1-way vented box active system Driver Configuration | |
Woofer: | 5 " | |
Frequency Range: | 42-5kHz | |
Power Handling: | 10-40W | |
Amplify | ||
Frequency Range: | 100Hz-20kHz | |
Rated Power: | 8Wx2 RMS | |
Signal-to-Noise: | > 88dB | |
Distortion: | THD <0.01% (8Ω @ 1KHz @ 1W) | |
Input Sensitivity: | 600mV | |
Input Impedance: | 22KΩ | |
Separate Degree: | > 60dB (L? R) | |
Others | ||
Finish: | Pearl white panel with black flat PVC | |
Dimension : | 245 × 258 × 172 | |
Net Weight (Kg): | 4.2 kg | |
Td> | ||
satellites | ||
System Type: | 2-way 1st sealed box system | |
Driver Configuration | Woofer: | 3 " |
Tweeter: | 20mm dome tweeter | |
Frequency Range: | 140Hz - 20kHz | |
Distortion: | 280Hz-20kHz = 1% (2.83 V / 1m) | |
Sensitivity: | 87dB 2.83V / 1m | |
Nominal Impedance: | 4Ω Span> | |
Power Handling: | 1-20W | |
Others | ||
Finish: | Pearl white panel with black PVC | |
Dimension : | 110 × 100 × 172 | |
Net Weight (Kg): | 0.84 k |
P>
P>
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Frédéric J.
Antoine C.
