By buying this product you get 44 loyalty points
Swans M200 MKII - Active Monitor Monitors
The Swans M200 MKII high-performance active speakers are truly versatile.
Used as a proximity monitor in the recording studio, as a compact multimedia speaker or connected to an i-Pod, the possible applications of the Swans M200 MkII are endless.
The M200 MkII will astonish you with its extreme neutrality and the sound level that can be achieved in spite of its reduced dimensions.
The M200 is equipped with volume and tone controls (bass and treble) on the front panel.
the amintegrated entertainment with the use of components of very high quality and can quite measure up to an external hi-fi amplifier.
General Data | |
Model | HiVi M200MKII |
System Series | Hi-end digital Multimedia system |
Acoustic System | |
System Type | 2-way 4th order active vented box system |
Drivers Configuration | 5 "mid-low driver, 25mm dome tweeter |
Frequency Range | 56Hz-20KHz |
Harmonic Distortion | 80Hz-20kHz≤1% (2.83V / 1m) |
Sensitivity | 87dB (2.83V / 1m) |
Nominal Impedance | 5Ω |
Power Range | 10-60W |
Amplifiers System | |
Rated Power | 35W ×2 RMS (5Ω, 1KHz, THD <0.1%) |
Frequency Range | 20Hz-20kHz |
Bass Adjust | ± 3dB (100Hz) |
Treble Adjust | ± 3dB (10KHz) |
Separation | > 60dB |
Signal-to-Noise | > 80dB |
distortion | THD <0.06% (8Ω, 1kHz, 10W) |
Input sensitivity | 650mV |
Input impedance | 22kΩ |
Other Parameter | |
Finished | Walnut wood veneer / Black flat |
Dimension (W × H × D (mm)) | 192 × 230 × 350 |
Net Weight | Main speaker: 7.8Kg Subsidiary speaker: 6Kg |
