Active Bookshelf Speakers Bluetooth 5.0 aptX HD WiFi 2x50W 24bit 192kHz Black (Pair)
Triangle's AIO Twin active bookshelf loudspeakers are a real concentrate of technology and know-how. Versatile, with extensive connectivity, they are perfectly adapted to today's uses. They also offer excellent sound performance, revealing a rich, precise and detailed sound.
Equipped with WiFi and Bluetooth 5.0 connectivity, the remote broadcasting of your music is done easily, directly from your smartphone or computer, with a resolution that can reach 24bit 192kHz. Still in this perspective of versatility, the AIO Twin has a Phono input to connect a vinyl turntable.
Hi-Res transmission : The AIO Twin allows you to stream your music in high resolution extremely simply, directly from a smartphone, tablet or computer.
Webradios & Services de streaming : With TuneIn, you can access podcasts, news, music, live sports or radio from around the world.
Phono : Enjoy your vinyl records by connecting your turntable directly to the dedicated input.
Multiroom : Install multiple pairs of AIO Twin speakers in your home to create a true multiroom audio system that can be controlled remotely throughout your home.
Audio-Video : Easily connect your TV to your speakers with the dedicated Toslink Optical input.
Bluetooth : Stream your music with ease with the Bluetooth 5.0 receiver, supporting aptX and aptX HD high definition transmission codecs.
WiFi : Enjoy superior sound quality thanks to wireless transmission via WiFi. It allows the reading of PCM streams up to 24bit 192kHz.
The free Triangle AIO mobile application, available on both the App Store (Apple) and the Google PlayStore (Android), gives you access to a wide range of streaming services directly from your smartphone or tablet. You can also access all your audio files stored on your device or on your local network, on a NAS or connected computer for example.
With LinkPlay technology, connect all your AIO devices on your network and control all your home audio equipment remotely, right from your app. Control the playback and playback options for each room in your home, enjoy equalizers for each room, or pair your speakers with each other.
The Triangle AIO mobile app also lets you take advantage of the biggest music streaming services and the vast content on offer. Use the famous platforms Deezer, Spotify, Qobuz or Tidal for their large catalogs of music or TuneIn to access web radios from around the world.
With the AIO Twin speakers, your vinyl records won't be put away. Thanks to the on-board MM phono preamplifier, connect your turntable directly to the speakers and listen to your records with ease.
For these AIO Twin, Triangle offers a selection of noble materials combining both acoustic performance and aesthetic qualities. The high-density wood particle cabinetry provides great sound neutrality. Its rigidity is a key element to avoid any sound coloration.
The speakers, equipped with elegant aluminum feet with rubber feet, dissipate vibrations efficiently. The sound message and the surface of your furniture are thus preserved
For several years now, Triangle has partnered with Maison Gabriel for the production of its speaker grilles. A true specialist in high quality fabrics, the brand offers a wide range of colored and textured finishes. Thus, the AIO Twin grille uses Bond fabric, a quality fabric with a unique look, in harmony with the different finishes of the cabinetry. The oblong shape of the grille makes the AIO Twin a real decorative object.
Product type | Active speakers |
Drivers | Tweeter 25mm Woofer 13cm |
Power handling | 2x50W |
Network | WiFi IEEE 802.11g/b/n 2.4GHz RJ45 10/100M LAN |
Supported sampling rates | PCM jusqu'à 24bit 192kHz |
Bluetooth version | 5.0 |
Supported Bluetooh codecs | AAC, SBC, aptX, aptX LL, aptX HD |
Inputs | WiFi 1x Stereo RCA 1x Jack 3.5mm 1x Optical Toslink Bluetooth 1x USB-A (USB Host) |
Outputs | 1x Subwoofer output |
Frequency response | 56Hz - 22kHz |
Supported audio formats | APE, FLAC, WAV, Apple Lossless (ALAC), AAC, AAC-LC, HE-AAC, HE-AAC v2, MP3, CBR/VBR |
Dimensions | 165 x 304 x 235mm |
Weight | 10.4kg (paire) |
Color | Black |
Quantity | Pair |
Color | Black |
Impedance (Ω) | NC |
Efficiency / Sensitivity (dB) | N/A |
Lowest frequency (Hz) | 56 |
Highest frequency (Hz) | 22000 |
Power (W) | 50.0 |
Number of ways | 2 |
Number of loudspeakers | 2 |
Speaker type | Active |
Speaker form factor | Bookshelf speaker |
