TRIANGLE BOREA BR02 Bookshelf Speakers 80W 89dB 51Hz-22kHz Walnut (Pair)
The Triangle Borea BR02 bookshelf speaker is the most compact model in the Borea range. It will easily fit on a dedicated stand, a shelf or an adapted HiFi cabinet. This model represents an excellent access point to the world of high fidelity and audiophily. It will indeed surprise you with its capacity to provide an immersive and ample sound.
By buying this product you get 34 loyalty points
Reference : 15994
349,00 €tax incl.
290,83 € tax excl.
Triangle Borea BR02
Triangle Borea BR02 Enceintes Bibliothèque 80W 89dB 51Hz-22kHz Noyer (La paire)
Each speaker is equipped with a 25mm EFS dome tweeter and a 13cm driver with natural cellulose pulp membrane. It is thus able to retranscribe all the richness and the subtlety of the timbres of the voices and instruments of your music. The bass on its side is not in retreat and is particularly surprising considering the reduced volume of this model.
The Borea BR02s will effectively soundtrack rooms up to 20m², while exhibiting the brand's signature dynamism. The BR02s can also be used in a home cinema system as surround effect speakers.
Des technologies performantes
The BR02 loudspeakers benefit from the technological and acoustic innovations of the Esprit Ez series, including the cabinetry and the driver cones.
EFS tweeter :
The tweeter equipped in the speakers of the Borea range benefits from a new generation system called EFS (Efficient Flow System). This system is based on the combination of a 25mm silk dome known for its neutrality, and a phasing piece, specifically developed to homogenize the diffusion of high frequencies. This system drastically reduces the directivity factor, regardless of where you are listening in the room. The driver's diaphragm is placed inside a horn cone, limiting edge effects for a clear high-frequency sound reproduction. This transducer is powered by a neodymium magnet motor, capable of generating a large magnetic power for a small footprint. It is associated with a heat sink to guarantee a better power handling.
Natural cellulose mid range driver :
The Borea range uses a midrange driver with a 100% natural cellulose pulp membrane that does not undergo any surface treatment. This avoids any coloring of the intermediate frequencies in order to reproduce voices with realism, while offering a characteristic grain of the most beautiful effect. The profile of the membrane has been reworked to increase the rigidity of the speaker and improve its frequency response.
DVAS system :
Following extensive research to reduce internal vibrations related to the cabinet, the Borea range of loudspeakers incorporates openwork internal panels made of MDF and EVA foam to stiffen the transducer and cabinet assembly. This process reduces structural vibration while absorbing low frequency vibrations.
This proprietary system, developed by Triangle and named DVAS (Driver Vibration Absorption System), uses a high density EVA foam gasket at the end of each internal bracing, ensuring a perfect contact between the driver and the bracing, thus reducing the vibrations generated by the driver and transferring only a small amount of vibration to the cabinet. This DVAS system ensures a high degree of neutrality and clarity, without sound coloration.
Decoupling :
Each speaker of the Borea range has its own decoupling system. The BR02s are delivered with rubber pads, protecting the underside of your speakers, but also limiting the transmission of vibrations.
Magnetic cover :
All Borea loudspeakers have a magnetic protective cover, leaving no screws or inserts visible.
Product typeBookshelf speakers
Number of drivers2
Number of ways2
Power handling80W
Sensitivity89dB/W/m
Frequency response (+/-3dB)51Hz-22kHz
High frequency roll-off2500Hz
Rated impedance (min/max)3.6 / 8Ω
Recommended room sizeUp to 20m²
Dimensions176 x 310 x 274mm
Unit weight4.87kg
ColorWalnut
QuantityPair
ColorWalnut
Impedance (Ω)8
Impedance (Ω)4
Loudspeaker diameter (mm)N/A
Efficiency / Sensitivity (dB)89.0
Lowest frequency (Hz)51
Highest frequency (Hz)22000
Power (W)80.0
Number of ways2
Number of loudspeakers2
Speaker typePassive
Speaker form factorBookshelf speaker
The Triangle Borea BR02 bookshelf speaker is the most compact model in the Borea range. It will easily fit on a dedicated stand, a shelf or an...
